blew the hydraulic filter off the filter base.
   / blew the hydraulic filter off the filter base. #1
Ed ke6bnl
splitting wood about 50 degrees and all of a sudden the filter with the filter body threads blew off. destroyed the filter base. The filter body appears to have a by pass that is free. filter is not that bad. What would cause this?
   / blew the hydraulic filter off the filter base. #2
Somewhere in the circuitry there is a pressure relief valve that is jammed.
Probably in the hydraulic control valve itself.
Possibly caused by crud and or corrosion.
Back years Jeep with certain motors would blow off filters and that was caused by front drive hitting the filter housing and jamming the pressure relief valve.
   / blew the hydraulic filter off the filter base. #3
I presume the filter is on the return line from the directional valve.
If this is correct I would suspect flow surge pressure spikes potentially fatigued the housing. If splitting wood were the cylinder jumps when the piece splits causes flow surges. How much surge is a combination of several factors some of which are cylinder size, operating pressure, tank line size, filter size, etc. this is called decompression shock since there is a volume of fluid compressed which also stresses the splitter frame.
I have blown filters off presses in factories from this flow surge
   / blew the hydraulic filter off the filter base. #4
Is this a factory splitter or a homemade job?
I put a shutoff valve on my return (between filter and tank) so I could change the filter without loosing any fluid.
When you arent paying attention and lean on the splitter and close that valve while it is running.....it does exactly what you describe.
Does it have a valve that you closed by mistake? or somehow pinched/kinked the return hose after the filter?
   / blew the hydraulic filter off the filter base. #5
Did you add another valve into the system? If so did you set it up with PB?
   / blew the hydraulic filter off the filter base. #6
Could be the filter housing was compromised by being hit with something and damaged, and it just decided to let go..... Would think bypass would have prevented it other wise....
Dale
2008 FORD RANGER SINGLE CAB TRUCK (A51406)
2008 FORD RANGER...
T3 Motion Patroller Segway (A51694)
T3 Motion...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
TEST YOUR BID BUTTON! (A51247)
TEST YOUR BID...
Case Maxxum 140 (A50120)
Case Maxxum 140...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
