Bleeding TC29
   / Bleeding TC29 #1
tow653
Gasconade County,Mo
New Holland TC29,Ford Jubilee
Think I had a valve stem pour into fuel tank.it kinda dissolved and clogged fuel filter. Changed fuel filter and am trying to bleed air out of lines. Cracked vent on top of pump and have fuel coming out. Cracked lines at injectors and am not getting fuel. Not wanting to burn starter up so only do for 20 or 30 seconds. How long should it take to get fuel at injectors? Or any other advice or tips? Thanks, Tim
   / Bleeding TC29 #2
Not very long.. make sure the throttle is wide open & the shut off is in the run position..
I hate to say this but, maybe a sniff of starting fluid will help spin it faster..
Does the system have a lift pump or is it gravity fed TO the injection pump??
Maybe pressurizing the tank will help..
   / Bleeding TC29
Takes forever if the wire on the fuel solenoid comes off. Glad it's back running
2005 KENWORTH T300 (A52472)
2005 KENWORTH T300...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
KONE CRANES SMV-25-1200 HEAVY LIFT FORKLIFT (A52472)
KONE CRANES...
Hyster H225E (A47384)
