Bleeding lines on new grapple install
   / Bleeding lines on new grapple install #31
Understood but I do believe my supply ckts are longer than the cylinder movement on the curl and dipper. I didnt think any cylinders were recirculatory
   / Bleeding lines on new grapple install #32
Most are. It's not about length, it's about volume. And cycling the cylinder(s) more than once. Which I have mentioned more than once. I'm drawing on 40 plus years of practical experience here, as well as 20 years of equipment dealership experience which includes being familiar with factory recommendations and service procedures from a wide range of manufacturers. If that's not good enough for the theorists, NASA employees and aircraft engineers here, I can't help it. I'm getting along just fine, thanks.
   / Bleeding lines on new grapple install #33
Haha RickB I do thank you for sharing your knowledge and I will even apologize for getting your panties in a wad. I am just trying to understand why. I am not questioning your advise simply asking you to expound on why, if you can. Telling someone to cycle it several times and it will work itself out does nothing to explain why.
Thanks again for your insight but if our/my questions bother you so much are you sure a forum is the place for you? With over 6k post i am sure you do know it is a place to ask your questions, share your knowledge, and overall comunicate with like minded people or at least people with the same interests.
I've never owned a dealership, and do not have 40 years experience with hydraulics but thanks to you and others I have at least a better working knowledge of many things I have never been familiar with before. Im still ignorant on tractors and their systems but less and less everyday
   / Bleeding lines on new grapple install #34
Just cycle the hyd circuits about 10 or more times, and be done with it.
If you continue to have air in the circuits, you might want to check the suction side of the pump.
   / Bleeding lines on new grapple install #35
My panties aren't in a bunch.
Every time the volume of air contained in the cylinder exits and returns to the reservoir, it carries a percentage of the volume of any air present with it. Cylinder size, hose diameter and length, as well as elevation between the valve and cylinder are some of the variables that determine how many cycles of cylinder stroke are required to remove all the air present. If you take your fingers off the keyboard for a minute and actually think about what happens when a cylinder is cycled, I'm pretty certain you can understand how the oil moves the air out and back to tank.
Pardon the pun, but it really isn't rocket science.
   / Bleeding lines on new grapple install #36
Pardon the pun, but it really isn't rocket science.:laughing::thumbsup:
   / Bleeding lines on new grapple install #37
Lol no pardon needed but unfortunately rocket science isnt my specialty either.. So that explanation did open my eyes.. I kept thinking once everything was up to pressure you had what you had.. taking my hand off the keyboard partially got me stuck in this rut a couple weeks ago when I originally asked. I got myself lost drawing it on the whiteboard.. I drew a cylinder and ckt, put a diff color dot at a specific distance from it in the cylinder. (This is where I went totally wrong and got my blinders stuck on hard) I tried to demonstrate to myself that ckt exercising and that dot would move into the cylinder. Then back to where it originated when relaxed. I completely overlooked the fact that the volume difference would probably put that dot someplace else. because of my cylinder orientation I was also leaning towards all air getting pushed past piston seals and exiting the flange seal. Couldnt see the forest for the trees thing.. thanks for the explanation I do truly appreciate it.
   / Bleeding lines on new grapple install #38
Air cycles out of the system without any bleeding required. I know this from experience. I don't need to know how it does it or the hydraulic fluid theory to know that it does. I don't know how my computer puts these letters on this thread but I know that it does put a D on the screen when I hit the letter on the keyboard and it has no wires so it transmits wireless. I don't need to know how that works either, it just does. One does not need to know theorem mechanics about tractors to know that if I pull back on the FEL lever, I expect the FEL to raise. I don't need to know how the pump is powered, fed, pressure delivered etc., just that it will work just like the air being removed from the new cylinder.
Fluid level being maintained with correct type in your tractor is about all you need to know as long as it is working which 99.99% of the time it will continue to work as long as all fluids are maintained and serviced as recommended.
   / Bleeding lines on new grapple install #39
You are absolutely right some do not wish to know and thats fine for sure. I asked the question because if someone here could answer I wanted to know.. On top of that it was a great ride to get there :) I learned something new today. I also learned I need to better communicate where I came to my conclusion from a little better. Many things learned in just a couple of banterings back and forth.
I also learned I really need to apologize to the OP for totally highjacking his thread very sorry RJ
   / Bleeding lines on new grapple install #40
I have always like to know how things work, even things that probably won't really profit me to know. I like to know just for the "knowing". I always have.
JOHN DEERE 635F 35' HYDROFLEX PLATFORM HEADER (A51247)
JOHN DEERE 635F...
2018 JLG G5-18A (A50123)
2018 JLG G5-18A...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A55852)
2015 Peterbilt 320...
FRONTIER MG20F LOT NUMBER 80 (A53084)
FRONTIER MG20F LOT...
New Kivel Skidloader Double High Back Bale Spear (A50775)
New Kivel...
JOHN DEERE 560M LOT NUMBER 28 (A53084)
JOHN DEERE 560M...
