Bleeding lines on new grapple install
   / Bleeding lines on new grapple install #1
RKJeepXJ
NC
LS R4047H
Everyone says the hydraulic system is self bleeding. I find that hard to believe. If I start out with lines run from my rear remotes to the front for my grapple, the fluid won't travel all the way up to the cylinder before it runs out of travel. If I cycle it a few times, yea it would eventually mix and a good amount of air would get pushed back on the return stroke. I just don't see this really bleeding it out well.
One thought I have is since I have male and female couplings up front, I could simply hook them together and actuate the valve and essentially bleed the loop. Then to only air introduced would be from the grapple hoses and cylinder. Seems better than nothing. Thoughts?
   / Bleeding lines on new grapple install #2
You are correct, some circuits will not never purge themselves of all air and require manual bleeding. Hooking the lines into a loop is a ideal way to clear most of the air.
   / Bleeding lines on new grapple install #3
I had the same question a while back and got many of the same responses but was also unsure and do not know the answer. But, I will have more info for you this weekend if my parts arrive. I have a completely dry hydraulics system on a backhoe and as you know many many circuits to clear of air.. So after thinking about it I have broken the system down into recirculatory section and the fill and bleed section..
The recirculatory system is the reservoir, pump, and valve gang/block this should self bleed.
However the circuits beyond the valve block just moves fluid a distance forward and a distance back.. so here is what I think the possibilities are with that
The pressure will compress the air and get a large amount of fluid into the cylinders and eventually the air will work its way back but only through repetitive cycling over a long period of time.
Or
The air molecules are smaller than the hydro molecules and the can be "pushed" past the seals in the cylinders and this is how it is self bleeding.
Or
Like you suggest they will either have to be manually bled each cycle at each cylinder or looped to force each circuit to recirculate itself. Hopefully it will be an enlightening adventure for all of us
   / Bleeding lines on new grapple install #4
Or
Bingo.
   / Bleeding lines on new grapple install #5
If that makes you sleep better, go for it.
   / Bleeding lines on new grapple install #6
Back in the 60'-late 80's while employed at a JD dealership all the FEL's and other farm equipment that I assembled the hydraulic components self bleed and I believe that will do the same today. One can get enough oil on ones clothes working around farm machinery without attempting unnecessarily to bleed the air out
   / Bleeding lines on new grapple install #7
Hah hey kennyd. Thanks for the reply.. btw I have pushed those hooks and shackle mount well past what I should be doing with them and they are still straight and strong. Thanks for the great product.
TxJim I was worried about that as much as anything. I didnt want to be spilling anymore hydro than I had to :)
RK, sorry for the highjack but at least its an on topic highjacking :)
   / Bleeding lines on new grapple install #8
All I can say is that after hooking up my dry hoses from the rear remote, and into the grapple cylinder, all the spongyness (is that a word?:)) seemed to go away in about 10 cycles of the grapple. Maybe took a minute. No bleeding necessary.
   / Bleeding lines on new grapple install #9
Hydraulic cylinders have seals that are oil tight not air tight.
Crack the fittings at each cylinder connection and move the lever until each leaks a small amount, re-tighten and do all the rest the same.
Cycle cylinder a few times, job done.
   / Bleeding lines on new grapple install #10
Thanks for the compliments Rick :drink: I'm glad your happy with the products.
2022 CATERPILLAR 306CR EXCAVATOR (A51406)
2022 CATERPILLAR...
2430 (A51248)
2430 (A51248)
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
ROADTEC RP-190E-3043 ASPHALT PAVER (A52705)
ROADTEC...
2011 GMC Acadia SLE SUV (A55758)
2011 GMC Acadia...
201 FORD F550 XL SUPER DUTY SERVICE TRUCK (A54756)
201 FORD F550 XL...
