Bleeding hydraulic lines on JD 790
   / Bleeding hydraulic lines on JD 790 #1
satchvet
I have just replaced one of the backhoe hydraulic lines on my JD 790 (backhoe model #7). I was looking for instructions in the manual as to how to bleed the line(s), but all that I can find is something that says "Lower stabilizers to the ground. Operate control levers to move all cylinders several times until backhoe runs smoothly." I have never had to bleed lines on any hydraulic system, but I thought there was more to it than what the JD manual says. Any help would be appreciated.
   / Bleeding hydraulic lines on JD 790 #2
Someone can correct me if I'm wrong, but I don't believe hydraulic lines need to be bled. This past spring I replaced 3 hyraulic lines on my rotary mower (each about 15' long) and it operated fine without doing any bleeding.
   / Bleeding hydraulic lines on JD 790 #3
I'm with Dave. No bleeding required. Just check the fluid level once you're all done and it's operating smoothly (all the air is out).
   / Bleeding hydraulic lines on JD 790 #4
To word it differently, yes the lines do require bleeding as they will have air in them. Fortunately, they are pretty much self-bleeding so as you cycle each cylinder the trapped air will work its way back to sump naturally. You may notice some sluggishness/sponginess in the cylinders until the air is out. It should only take a couple of strokes to be all set /forums/images/graemlins/smile.gif
   / Bleeding hydraulic lines on JD 790 #5
Just extending the cylinders to their limits a couple times will take the air out and no bleeding required.
   / Bleeding hydraulic lines on JD 790 #7
LBrown59
Welcome to TBN.
To get the pressure out of the lines to install new hyd. hoses, with the tractor turned off, lower all hyd. equipment to the ground. Cycle all controls in all directions until there's no movement in any attachments (FEL, BH...). You can now remove the hose(s).
   / Bleeding hydraulic lines on JD 790 #8
LB,
Also be aware that when you take a line off, if the cylinder is at an angle (as in a FEL or back hoe), all that fluid in the cylinder can come running out!
-Lloyd
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
SHOP MADE MANIFOLD TRAILER (A58214)
SHOP MADE MANIFOLD...
2015 CATERPILLAR  XQ30 GENERATOR (A58214)
2015 CATERPILLAR...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2000 Hyster S50FT (A55973)
2000 Hyster S50FT...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
