Bleeding Hydraulic line
/ Bleeding Hydraulic line #1
drivadesl
Hudson Valley, NY
New Holland TN-70A, Kubota U-35 Mini-Ex,SCAG Wild Cat, Cub Cadet 109
I just replaced 3 hydraulic hoses on my kubota mini ex. These were for the boom cylinders supply and return. Is there a need to bleed the air out of hoses when starting her up the first time? Or will the air work itself back to the reservoir by itself?
I replaced similar hoses on my tractor loader at one time, and didn't do anything, and in no time it worked perfectly after running the cylinders in and out. Anything to be concerned with here?
Thanks.
/ Bleeding Hydraulic line #2
Cycla the cylinder two or three times, holding the lever for a few seconds at each end of the cylinder's stroke. You'll be good to go.
Thanks Rick I'll give it a try.
2004 International 4300 ASM Altec AM855 55ft. Bucket Truck (A64194)
2004 International...
2008 Ford E-350 Cargo Van (A61573)
2008 Ford E-350...
1980 Gleaner F2 with heads (A61307)
1980 Gleaner F2...
2018 Infiniti Q60 AWD Coupe (A61574)
2018 Infiniti Q60...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
iDrive TDS-2010H...
