bleeding gator cooling system
   / bleeding gator cooling system #1
MaJYk
Bronze Member
South West Indiana
John Deere 3720
I'm havin problems gettin the coolant in my 620 xuv to circulate. It has a coolant bypass heater in it, and it was filled using the cap in the line at the heater core (the high point of the system). Any advice or links to past threads would be appreciated.
   / bleeding gator cooling system #2
Like the kawasaki mule with the same engine, i think, you need to elevate the front end slightly while filling. this would not be on just adding, but filling to capacity if the whole system has been drained. if it was just a little low you would not need to elevate.
   / bleeding gator cooling system #3
I had to fill mine shortly after I bought it. The factory didn't connect a coolant hose and I lost a lot of antifreeze. Problem is I don't remember all the steps and don't have the book with me tonight. I do know you fill the tank, get it up to operating temp, remove the cap under the bed to bleed air, add as necessary. I don't remember if you remove the cap when it is hot or wait until it cools. It does take a while because you have to let it cool completely before trying it again. Mine belched out a lot of antifreeze all over the engine. I'll check back tomorrow evening to see if someone has gotten you the exact procedure. If not I'll check the book and let you know what it says. I do know it doesn't say anything about elevating the front of the machine.
Well, it's finally circulating. Heater hoses and radiador both warmed up nicely and fan cycled on and off several times. What a contrary process.
   / bleeding gator cooling system #5
I thought it was a bit much myself. Glad you got it going.
2022 Wacker Neuson SM100 Mini Skid Steer (A52748)
2022 Wacker Neuson...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2017 Ford F-150 Pickup Truck (A50323)
2017 Ford F-150...
Pickup Truck Bed (A51691)
Pickup Truck Bed...
2009 Hyundai Sonata Sedan (A50324)
2009 Hyundai...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52577)
2013 UTILITY VS2RA...
