Bleeding Fuel System of Air
   / Bleeding Fuel System of Air #1
JamesM
I have JD 935 mower with a Yanmar engine. It was run out of fuel the other day and I'm having a heck of a time getting it going again. There is a bleed screw on the fuel filter to bleed the primary low pressure side which I did and I've got all the lines cracked on the pump and I'm getting no fuel. I've had to do this before and got it going but no luck this time. These tiny pumps move so little fuel it seems they're very hard to bleed.
   / Bleeding Fuel System of Air #3
On my Yanmar there was a bleader valve on the filter and one on the pump. After bleading both it fired right up. If you do not have the JD manual get one. It explains in detail how to do this.
   / Bleeding Fuel System of Air #4
   / Bleeding Fuel System of Air #5
Not sure about yours, the Yanmar tractors have 2 bleeder screws on the filter. You have to bleed both of them the one on the fuel tank side first then the one on the pump side, then the one by the pump. So yours may be different than that, so thats all I can tell you.
   / Bleeding Fuel System of Air #6
   / Bleeding Fuel System of Air #7
My YM2020, 3 cylinder, has a spring loaded bleeder on the filter and a spring loaded bleeder on the injector pump. Does not take a screwdriver, just push it. My YM 1700, 2 cylinder, has two on filter and one on injector pump, these need a screwdriver.
   / Bleeding Fuel System of Air #8
   / Bleeding Fuel System of Air #9
loosen your fuel bowl and then retighten. This will break the vacuum which is preventing the fuel from flowing.
   / Bleeding Fuel System of Air #10
2016 Ford Fusion Passenger Car, VIN # 3FA6P0G79GR191653 (A50324)
2016 Ford Fusion...
2013 Chevy Silverado 2500 HD (A52128)
2013 Chevy...
UNUSED AGT H15R EXCAVATOR (A51243)
UNUSED AGT H15R...
2016 FORD F-350 XL SUPER DUTY CREW CAB FLATBED (A51243)
2016 FORD F-350 XL...
2012 Ford E-150 Passenger Van (A51692)
2012 Ford E-150...
2016 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51242)
2016 CATERPILLAR...
