Bleeder screw on fuel filter - New Holland
   / Bleeder screw on fuel filter - New Holland #1
TEV
Texas
New Holland TN75
I have a New Holland TN75 tractor. This weekend we had to bleed the fuel lines which involved backing off the bleeder screw from the top of the fuel filter. Unfortunately, we wound up taking the bleeder screw completely out of the filter assembly. When we tried to tighten the bleeder screw, it would tighten down but not tighten all the way causing the fuel to continue to leak allowing the filter to suck air. I'm new to the tractor business and am hoping this is a replaceable part. Any help would be appreciated.
   / Bleeder screw on fuel filter - New Holland #2
You can purchase a new filter assembly from your New Holland dealer.
   / Bleeder screw on fuel filter - New Holland #3
You either have the screw cross-threaded or have lost the copper sealing washer, or have a chip of paint under the screw head or the washer.
   / Bleeder screw on fuel filter - New Holland #4
You can drill out the threads and use a brass reducer and a brass plug to stop the leak. They make a replacement bleeder for brake cylinders or calipers available at part stores. You should be able to find something that will work.
Richard
CHALLENGER MT525B TRACTOR (A51406)
CHALLENGER MT525B...
UNUSED FUTURE FT2P 12 VOLT PUMP (A51248)
UNUSED FUTURE FT2P...
7021 (A50322)
7021 (A50322)
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A53472)
2012 RAM 5500...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
BUSH HOG 1815R1 BATWING MOWER (A51247)
BUSH HOG 1815R1...
