blades won't engage
   / blades won't engage #1
weskar
Treasure Coast , Florida
Kubota L4240HSTC
I have a Toro Z-150 zero turn with a 20hp Kohler, the engine runs fine, recently the pto/ electric clutch has been has been disengaging - engaging. I can't seem to find a wire or any loose connections. Any suggestions ?
   / blades won't engage #2
Are the blades not engaging at all, in which case I'd be looking for a loose wire or blown fuse, or are they engaging and disengaging without you turning them on and off, in which case I'd be looking for a loose wire or insulation rubbed off a wire or a defective switch. And I'm no mechanic; that's just my best guess.
   / blades won't engage #3
You could also check the gap on the eletric clutch with a feelers guage which came with some mowers .Do you have the manuals for it
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
(4) STEEL CARTS W/ WHEELS (A51248)
(4) STEEL CARTS W/...
2019 JOHN DEERE 8295R LOT IDENTIFIER 170 (A53084)
2019 JOHN DEERE...
(2) 300 GALLON POLY TOTE (A51248)
(2) 300 GALLON...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
