Blades will not engage B7510
   / Blades will not engage B7510 #1
jkm
SC
Kubota B7510
Well, yesterday I tried to engage the blades on my B7510 after not using the Midmount mower all winter. When I tried to engage the blades, the motor bogged down until I pushed the clutch in. I tried again and again. Still nothing. Finally I took the shrouds off and pulled on the belt. After rocking the belt back and fourth.....I was able to get back on the tractor and engaged the blades. It was really loud. I thought it was rubbing on the metal so I turned it off and greased all the spindles and the shaft. It was still loud for a bit. It is somewhat quieter now, but no where near as quiet as before. The tractor only has 36 hrs on it. Only about 10 hours on the mower. Any ideas?
   / Blades will not engage B7510 #2
Take all the belt and pulley covers off and look for mouse housing or rocks binding the system.
If that's not it, something is bent or worn, like a pulley or a blade spindle.
iDrive TDS-2010H...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A59228)
2025 Kivel 42in...
2008 MACK CHU613 TRI AXLE 16FT DUMP TRUCK (A58018)
2008 MACK CHU613...
Wacker Neuson EZ26 (A60462)
Wacker Neuson EZ26...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59905)
2019 INTERNATIONAL...
2020 CATERPILLAR 336 EXCAVATOR (A60429)
2020 CATERPILLAR...
