Blades slowing to a stop in grass!
   / Blades slowing to a stop in grass!
Had a quick look underneath today and I can easily move the diff lock pedal up and down easily but there's nothing holding the pedal in the up position.
Looks like I need to remove the deck to see the majority of the linkage.
   / Blades slowing to a stop in grass! #22
Look under jdparts.com for the x740, and under alphabetical "differential lock pedal and linkage".
There you will see the torsion spring, part #M145953 that may be either missing, broken, or not positioned correct to return the pedal.
Haha.... oops!
Nothing to see here folks...... I didn't realise that the diff lock pedal went down when you put the brake on!! [proper noob mistake]
   / Blades slowing to a stop in grass! #24
That's a good one... glad it was an easy fix. I recall seeing my pedal all the way down once and the thought went through my mind "what's broken now". :)
Took the mulching kit off today and tried it in 8-10" of lush damp grass - WOW!!
I wasn't hanging around and the 740 coped easily. I guess, when not mulching, you should try to cut going in an anticlockwise direction so the cut grass is thrown out and not back onto the grass yet to be cut.
   / Blades slowing to a stop in grass! #26
yea, that is always good and prevents a lot of clogging under the deck.
even alternating rows is better than blowing the same windrow over and over.....
2008 Sterling Acterra Ambulance (A56858)
2008 Sterling...
2025 SDL00L 36C Stand-On Mini Track Loader Skid Steer (A55851)
2025 SDL00L 36C...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2019 CATERPILLAR 740GC OFF ROAD DUMP TRUCK (A52707)
2019 CATERPILLAR...
2020 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A55973)
2020 Caterpillar...
