Blades for the 1046
   / Blades for the 1046 #1
anthonyk
houston texas
Century 3647
A lot of us have complained about the quality of the oem blades on the 1046, myself included. Plus, Gator apparently does not make a replacement.
I finally found an aftermarket blade set. They cost about the same as the oem's but what a difference in quality. They're made of some type of "XHT" material.
All I can say is that when I compared them to the stock blades, these are MUCH thicker, heavier, and make a totally different sound when they're cutting.
Here's a link, and I hope it helps,
anthony
Lawn Mower Blades - Gator Lawn Mower Blades - Lawn Mower Belts and Parts
p.s. for those of you with other size cutting decks, they do sell the Gator, and something called a Predator, which is supposedly even better than the Gator and made with the same XHT steel. Plus customer service on the phone was excellent.
   / Blades for the 1046 #2
Don't LT1046 use a star pattern on the blades for the 46-inch deck?
I can't seen to find the correct part numbers wading through all the pages of blades.
Can you post up the correct part numbers and quantity you ordered?
Thanks.
Mine has the 3/4 inch round hole.
I'm sorry that I don't have the part number for the star shaped one, but their customer service is excellent.
good luck,
anthony
Misc Pallet of Nails and Building Supplies (A57454)
Misc Pallet of...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
Rooster Weathervane (A55853)
Rooster...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
2014 Aerway Aerator (A55973)
2014 Aerway...
(4) Ratchet Straps (A57453)
(4) Ratchet Straps...
