Mowing Blades for mower
   / Blades for mower #1
Scrounger
Platinum Member
Bethlehem (Lower Nazareth) PA
Kubota BX2230
I'm looking for information on a new set of blades for my 60" deck on my BX. I was going to go for a Kubota mulching kit but I'm not heard good things on it. I'm looking for mulching blades however since I do want to chop the lawn up as much as possible. I'm a bit tired of the trails around the lawn. :)
On the blades, preferably something that is a direct bolt on.
   / Blades for mower #2
There has been a lot of discussion on this board in the past about "gator blades". If you do a search you should be able to find plenty of information about them including the where to order them online.
There are a few posts describing how to make them fit on the 60" bx mower deck. Here's one of them gator blades
   / Blades for mower #3
Scrounger said:
I'm looking for information on a new set of blades for my 60" deck on my BX. I'm a bit tired of the trails around the lawn. :)
Scrounger - I had problems with trails of cut grass, also. I changed to Kubota high lift blades and have been satisfied with the results.
I mow my 2 acre lawn with a B7500 and 60" ground contact MMM. I get the best cut by: 1) starting with a clean (underside) deck, 2) running high lift Kubota blades, 3) cutting at 3" height, 4) running engine at PTO speed (2,600 RPM), keeping ground speed a little slower than I would like to naturally run, 5) discharging clippings outward onto already-cut area, and 6) holding the discharge chute up with a bungee cord (need to be careful). I am satisfied with the cut that I get. When the lawn is very long, and/or wet, I either run back over any windrowing to disperse it, or pick it up with a pull-behind sweeper. Best wishes!
   / Blades for mower #4
I have been using the 54" MMM with mulching kit/high lift blades on my BX24 with excellent results. You do need to keep up with the mowing and if it gets a bit high go over it twice, once with the deck a bit higher, then again at normal height, but hey, thats more time I get to spend in the seat.
As suggested above, PTO rpms and drive a bit slow.
   / Blades for mower #5
You would say then that the mulching kit was worth it? Problem I run into is mowing around alot of our mulched areas, and trying not to blow cut grass onto the nice black mulch. I was thinking of just using a discharge cover but didn't know if that would do it.
I had looked at gator blades this morning on ebay, but was still thinking about a mulch kit.
   / Blades for mower #6
I have a 54"MMM on my BX1500 with the standard Kubota blades. Lift the chute deflector does help a good bit (once again be careful of others around you).
   / Blades for mower #7
IMHO the mulching kit was worth it. I never have to worry about the mulched areas unless I accidently cut the corners too close and swing the deck over them.
   / Blades for mower #8
I have got the 54" "finish" deck and mulching kit as well. I have not met grass that it could not cut in my lawn, and many times cut it wet. It also made quick work of the leaves this fall, and I have a lot of trees.
-dan
   / Blades for mower #9
Looks like I'll give the mulching kit a try, I think I was quoted $150 for since I have the 54" finish deck as well. Thanks for the comments.
2005 Pierce Enforcer Fire Truck (A50323)
2005 Pierce...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A49461)
1993 Ingersoll...
2018 Skyjack SJ1056TH 10,000lb 4x4 Rough Terrain Telehandler (A49461)
2018 Skyjack...
2003 FONTAINE TL50-NGB TRI AXLE RGN TRAILER (A51222)
2003 FONTAINE...
2007 Ford F350 Super Duty (A50514)
2007 Ford F350...
