Rotary Cutter Blade Tips
   / Blade Tips #1
ECD
Basom, NY
Ford 2600
I recently bought a Ford 2600 with several attachments. The brush hog is older and I'm not able to identify the make/model. I sharpened the mower blades, but later realized the blade tips were laying back, rather than engaging with the grass. Any advice as to how to fix this?
   / Blade Tips #2
The brush mowers I have worked around rotate counterclockwise and viewed from the top of the deck. Little lawn mowers (21") rotate clockwise. Are you saying someone put the blades on backwards? Remove blades and install properly seems like it might be the answer. You can find owners manuals at Bushhog. The concepts of brush cutters do not vary between manufacturers. http://www.bushhog.com/uploads/documents/BHRazorbackBH4-5-6OM-14.pdf
   / Blade Tips #3
On some models it's easy to put them on upside down. Don't even need to pay attention to direction of rotation. Just look at the angle of the sharpened edge. the cutting edge should be on the bottom of the blade, not the top as it would be if they are on upside down. Neighbor did that with his JD lawn mower several years ago. Brought it down for me to look at. He was very embarrassed when we discovered they were upside down. :)
Only other thing that will cause "lazy" swinging blades it running the PTO too slow. The cut quality difference is obvious with only a couple hundred RPM difference.
Let us know what you discover.
Lastly, pictures say a thousand words. :)
Welcome to TBN.
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2004 JOHN DEERE 310SG BACKHOE (A51242)
2004 JOHN DEERE...
PALLET OF MISC LINCOLN ARC WELDER, AIR COMPRESSOR (A51244)
PALLET OF MISC...
2024 CATERPILLAR 305CR EXCAVATOR (A51242)
2024 CATERPILLAR...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
2014 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2014 Ford F-450...
