Blade Tip Speed -RZT 54
   / Blade Tip Speed -RZT 54 #1
WSJ
Western NY & Northwestern PA
Kioti CK25
Can anyone tell me the blade tip speed of this mower? I presume it's the same for the entire RZT series but I just can't seem to google up the spec even though most other manufacturers provide one.
Thanks. -WSJ
   / Blade Tip Speed -RZT 54 #2
I don't know if this is 100%, but I've read that stamped decks spin at 'residential' speed, where fabricated decks can spin at 'commercial' speed.
Joel
   / Blade Tip Speed -RZT 54 #3
Joel
I don't know if that is true or not, but John Deere's 7 iron deck is stamped but is just as thick and probably more durable than most of the others fab decks. It takes a heck of a piece of equipment to make those out of 7 guage steel.
   / Blade Tip Speed -RZT 54 #4
I agree Al. It probably has to do with the gauge of the metal as opposed to being stamped or fab'd. I'd take a 7-iron over most fab'd decks regardless.
Joel
   / Blade Tip Speed -RZT 54 #5
What is the blade length? Are the pulleys the same from engine to blade?
   / Blade Tip Speed -RZT 54 #6
Don't know the blade length, but if the blade is 20 in, and the pulleys are the same, the blade tip speed is 18,840 FPM.
Thanks. I pick up the mower next week and those are things that can be determined, measured, and calculated.
Seems odd that Cub doesn't just provide a spec. I understand that this speed is less than the 19500 or whatever on a Ferris or Grasshopper or other commercial mowers but whatthe heck, it's called R Z T for a reason! -WSJ
   / Blade Tip Speed -RZT 54 #8
Blade tip speed will depend on the length of the blade, and the rpm of the deck spindle. If the blades are longer than I guess-ti-mated, the the blade tip speed will be faster. For some 60 in mower decks, they will use a 23 in bld. That computes out to 21,665 FPM
The 33 in Snapper, with the engine turning 3600 rpm, and the deck spindle turning 3600 rpm, the blade tip speed will be up around 31,o86 FPM.
The deck pulley, if larger than the engine pulley, will have a lower blade tip speed, but some additional torque. .
I know it turns fast as it will suck the dirt off the ground.
If you are inclined to get more blade tip speed, then you can reduce the deck pulley size.
16FT box truck (A53424)
16FT box truck...
1991 John Deere 2355 (A53317)
1991 John Deere...
2019 KENWORTH T800 KILL TRUCK (A58214)
2019 KENWORTH T800...
(APPROX. 25) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 25) 4' X...
RHINO DB150 LOT NUMBER 73 (A53084)
RHINO DB150 LOT...
2020 Terex RL4 Towable Light Tower (A55851)
2020 Terex RL4...
