Blade removal - Woods RD6000
   / Blade removal - Woods RD6000 #1
Wheeldog
NW CT
Kubota B2410HSD
I need to take the blades off my RD6000 finish mower for the first time, to get them sharpened. I took the covers off and started looking at the access to the blades. The mower manual shows a 'spindle wrench' that engages two bolt heads on top of each pulley. There are also a couple of through-holes in each pulley, so I thought I'd drill a couple of holes in a 2x6 and drop a couple of long bolts down through to hold the pulley from turning while I loosened the cap screw in the end of the spindle. That was, until I realized I couldn't get at the center pulley with anything that thick.
Anybody with one of these mowers have a clever trick for holding the pulleys in place? I'm hoping that this is much easier than I'm making it out to be /forums/images/graemlins/blush.gif
(BTW, the 6' and 7' models use a different means to hold the blades in place that doesn't look to require that the pulley be secured).
Thanks! /forums/images/graemlins/wink.gif
1992 GROVE AP-308 CRANE CRANE (A53426)
1992 GROVE AP-308...
2021 CASE IH 345 LOT NUMBER 12 (A53084)
2021 CASE IH 345...
2014 Ford Escape (A50324)
2014 Ford Escape...
Gravely Proturn 472 (A50123)
Gravely Proturn...
Pallet Fees (A50775)
Adams 5 Ton HC Spreader (A53473)
Adams 5 Ton HC...
