Blade removal - Woods RD6000
   / Blade removal - Woods RD6000 #1
Wheeldog
NW CT
Kubota B2410HSD
I need to take the blades off my RD6000 finish mower for the first time, to get them sharpened. I took the covers off and started looking at the access to the blades. The mower manual shows a 'spindle wrench' that engages two bolt heads on top of each pulley. There are also a couple of through-holes in each pulley, so I thought I'd drill a couple of holes in a 2x6 and drop a couple of long bolts down through to hold the pulley from turning while I loosened the cap screw in the end of the spindle. That was, until I realized I couldn't get at the center pulley with anything that thick.
Anybody with one of these mowers have a clever trick for holding the pulleys in place? I'm hoping that this is much easier than I'm making it out to be /forums/images/graemlins/blush.gif
(BTW, the 6' and 7' models use a different means to hold the blades in place that doesn't look to require that the pulley be secured).
Thanks! /forums/images/graemlins/wink.gif
2025 CFG Industrial MX20R (A50123)
2025 CFG...
2015 Kubota KX71-3S Mini Excavator (A52377)
2015 Kubota...
2025 JMR Tree Boom Skid Steer Attachment (A51691)
2025 JMR Tree Boom...
2012 International ProStar Sleeper Cab Truck Tractor (A51692)
2012 International...
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
6 Yard Commercial Dumpster (A51691)
6 Yard Commercial...
