Rotary Cutter Blade not spinning fast enough
   / Blade not spinning fast enough #1
grouda
I've got a Land Pride rcr 1560 and at 2500 RPM's on my 34 HP Kubota the blade is not spinning fast enough to cut. Any ideas on what might be wrong?
   / Blade not spinning fast enough #2
What does the tach on your Tractor show for PTO RPM output? Not being familiar with your mower are there belts that may be slipping? Is there an idler engagement pulley that tensions a belt to spin the blade?
   / Blade not spinning fast enough #3
Blades not tight on spindle, belts loose, gearbox gears stripped out, Tractor PTO shot. Let us know? Ken Sweet
   / Blade not spinning fast enough #4
Slip clutch working properly?
   / Blade not spinning fast enough #5
Set up for use on 1000rpm PTO?
larry
   / Blade not spinning fast enough #6
If it has a shearbolt, maybe the shear bolt is sheared, but there's still enough friction between the two shafts so that it looks like the blades should be spinning fast enough to cut??
   / Blade not spinning fast enough #7
With the tractor turned off but the pto engaged, attempt to move each of the blades by hand from underneath. On most mowers the blade will yield a certain distance (maybe 6" to a foot) and then come to a stop. If the blade continues to turn then remove the pulley guards and attempt to visually identify the slip point.
Good luck.
Ariens IKON 42 42in Zero Turn Mower (A55851)
Ariens IKON 42...
flooring (A55758)
flooring (A55758)
(16) 12" CHANNEL IRON (A57192)
(16) 12" CHANNEL...
UNUSED IRGC40 MINI ELECTRIC GOLFCART (A57193)
UNUSED IRGC40 MINI...
2009 Pontiac G6 Sedan (A55853)
2009 Pontiac G6...
1000 Gallon Supply Tank (A53314)
1000 Gallon Supply...
