Rotary Cutter Blade not spinning fast enough
   / Blade not spinning fast enough #1
grouda
I've got a Land Pride rcr 1560 and at 2500 RPM's on my 34 HP Kubota the blade is not spinning fast enough to cut. Any ideas on what might be wrong?
   / Blade not spinning fast enough #2
What does the tach on your Tractor show for PTO RPM output? Not being familiar with your mower are there belts that may be slipping? Is there an idler engagement pulley that tensions a belt to spin the blade?
   / Blade not spinning fast enough #3
Blades not tight on spindle, belts loose, gearbox gears stripped out, Tractor PTO shot. Let us know? Ken Sweet
   / Blade not spinning fast enough #4
Slip clutch working properly?
   / Blade not spinning fast enough #5
Set up for use on 1000rpm PTO?
larry
   / Blade not spinning fast enough #6
If it has a shearbolt, maybe the shear bolt is sheared, but there's still enough friction between the two shafts so that it looks like the blades should be spinning fast enough to cut??
   / Blade not spinning fast enough #7
With the tractor turned off but the pto engaged, attempt to move each of the blades by hand from underneath. On most mowers the blade will yield a certain distance (maybe 6" to a foot) and then come to a stop. If the blade continues to turn then remove the pulley guards and attempt to visually identify the slip point.
Good luck.
1988 Butler Equipment Trailer (A50515)
1988 Butler...
2016 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER TRUCK (A52141)
2016 INTERNATIONAL...
2010 International 4400 National Crane 300C 56FT 8 Ton Crane Truck (A50323)
2010 International...
2015 Volvo VNL300 Semi (A50514)
2015 Volvo VNL300...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A52748)
2020 Massey...
2012 Club Car Carryall 1 Utility Cart (A51691)
2012 Club Car...
