Blade attachment for FEL?
/ Blade attachment for FEL? #1
TractorLegend
Platinum Member
Randle, WA
2012 DK 45HST SE w/ FEL
I have a Kioti CK30HST with a KL130 loader. Is there such thing as a dozer type blade attachment to go in place of the bucket? Theres 4 pins holding the bucket on.
I think that would be ideal for my dirt smoothing duties as opposed to having to remove the rear mower all the time.
/ Blade attachment for FEL? #2
I can tell you without reservation that you can smooth things out with that bucket much better than using a blade. It is one thing to use a blade on a dozer, quite different with one with tires. Using the heel of the bucket to regulate backdragging and forward digging makes a big difference. When I am doing a lawn or large areas, I lag screw a 2x6 that is a few feet wider than the bucket on either side. Makes for easier leveling and moves much more dirt.
is the board mounted under the edge bit? (bottom of the bucket working edge)
/ Blade attachment for FEL? #4
Kasco Mfg. makes a blade that can be installed in place of the bucket. It is a manual angle, but has a hydraulic option, designed to move snow and other loose material has spring controlled breakover for snow or can be locked rigid for dirt or stone.
/ Blade attachment for FEL? #5
Yes, my buvcket has some holes just behind the cutting edge steel. I just lie the board down flat, place the bucket on top of it and lag it to the bottom. It works well from straight down to flat when back dragging. I use it flat when going forward.
/ Blade attachment for FEL? #6
Wow, 2x6? That seems so simple and cheap, Very ingenius! 8' seems like it wood be a good working length, What is your experience? 10' too much? Just curious...
Ken
/ Blade attachment for FEL? #7
Just depends on the size of your tractor. I'm using 50hp. A 10-12 board works for me. If I am in tight quarters I use a shorter board. For a smaller bucket a 6-8 footer might be the ticket.
2003 CASE 70XT SKID STEER (A64279)
2003 CASE 70XT...
2017 GMC Sierra 2500 HD 4x4 Crew Cab Pickup Truck (A64556)
2017 GMC Sierra...
2008 MACK CHU613 DUMP TRUCK (A63569)
2008 MACK CHU613...
2025 Wolverine BC-13-72W 72in Brush Cutter Skid Steer Attachment (A64553)
2025 Wolverine...
AUCTION STARTS HERE @ 9AM (A64278)
AUCTION STARTS...
2013 Hitachi ZX160LC-5N Hydraulic Excavator (A64553)
2013 Hitachi...
