Blackberry Menace
/ Blackberry Menace #1
Harv
Elite Member
California - S.F. East Bay & Sierra foothills
Kubota L2500DT Standard Transmission
Looking ahead on my culvert project, there is an obstacle near the site of future culvert number 2. There is a stand of the dreaded blackberries, about 8 feet high right at the approach to that creek. I would dearly love to demolish about 200 square feet of the stuff.
I have an as yet untested 5' bush hog, but the terrain from which the blackberries spring is "uncharted", so to speak. The surrounding area is quite rocky and uneven, so I hesitate to wade in with my shiny new mower.
Any first-hand experience out there on this one? Can I trounce the devil with my 'Bota somehow, or should I invest in a machete and wage battle by hand?
An anecdotal aside here -- As I began scraping away on culvert #1 I was subconsciously annoyed by a small dead tree that I had to keep working around and whose branches I kept eating every time I whipped the tractor around to dump a load of soil. Not yet thinking like a tractor guy, I was making mental notes to come back with a saw and take that puppy down. Then I remembered the talk I had seen on this board about knocking 'em over with the loader.
. I raised the bucket in challenge and slowly drove straight into the little pest, and almost shouted with glee when I saw how easily the tree just picked up its roots and moved out of the way.
If I was a cigaratte-smoking kind of guy, I would have lit one up after that one. /w3tcompact/icons/laugh.gif
/ Blackberry Menace #2
Harv, I have about a 50' row of blackberries and 4' wide, and each year when they are through producing (about mid-June here), I mow them down with the brush hog, fertilize and water. You know blackberries produce next year on the stalks that grow this year. Then the stalks that produced die and a new crop starts. I guess the bottom line is that I don't know about the rocks, etc. that might be under the blackberries, but otherwise, mowing them with the brush hog is the fast, easy way to cut them down.
Bird
/ Blackberry Menace #3
I'd go at that situation with both methods you mentioned. First, I'd go in with a machete (or similar appropriate weapon for berry warfare) and see what lies within the mess, working my way around and in. What's on the ground? Nothing, rocks, logs, limbs, debris? If it was clean and mowable, I'd be in there with the bush hog in a heartbeat. Otherwise, I'd sharpen my machete and prepare for berry bush battle, knowing I could always use the front loader to cart the downed bushes away.
Bob Pence
/ Blackberry Menace #4
Harv, I forgot to respond to your question <font color=blue>should I invest in a machete</font color=blue>. The question made me wonder whether you've used one before or not. If you have, then you can ignore this, but if you haven't . . .. Buy the heaviest one you can find; heavier works better. And secondly, if you take a straight swing, as you would with an ax, you'll work yourself to death. They work much better and faster if you learn to strike and slice (pull the handle towards you) at the same time. In other words, you have to use it as a combination knife and ax. It took this dummy awhile to learn to use mine effectively, but when I watched a couple of guys using them to cut down 2" to 4" cedars when I was doing good to cut little vines, I finally learned.
Bird
/ Blackberry Menace #5
Yeah, ain't it fun: digging, crunching, knocking things over, pulverizing, cutting, smashing. Actually, we all knew these things instinctively when we were 5 years old, before all that Freudian superego stuff civilized us.
As you have discovered, trees with weak or rotten roots can be pushed over. The issue for your bRush hog, as you speculate, is whether your blade will start clanging continously into protruding rocks. Not good, sounds like Gotterdammerung, and can be dangerous. Try driving in with your hog lowered but with the PTO off just to get a feel for the clearances.
Glenn
/ Blackberry Menace #6
Great Opportunity for a sickle bar mower! Thorns can and do create painful reminders of the blackberry wars. They can even cause the dreaded 'flats'. At any rate, a good echo weed eater with brush blade will work wonders also, but the less physical labor the bettor. I cleared a 5 acre addition on my campground years ago of briars, and no matter how you work it, they will make you pay for the experience. Good luck Harv, Have fun!
/ Blackberry Menace #7
Your post brought some fun memories. A few years ago I took my tractor up to my mother-in-law's place. She had about a 50 x 100 blackberry "area". They were about 8-12 feet tall and completely unmanageable.
Using the teeth on the loader I pulled them out of the ground and soon ended up with big rolling masses. I kept rolling them around crunching them up into a tight wad until I couldn't even lift, roll or push them anymore. She eventually lit the piles after the greenery had gone away.
As to the machete, in skilled hands they are amazing. The 70+ year old guy that surveyed our "wild" property just blew me away. He had a young guy (65+) assisting him. I don't even know if my tractor could have kept up with the rough grade of the land. He would stop and run a stone over the edge to keep it sharp. Blackberries are a another story though, those things always end up around your leg or neck! They are ALIVE and know you are there!
When I did my mother-in-law's place I considered it work. I also used the backhoe to "weed" the blackberries that had overtaken a once well maintained large plant "garden" on the hillside. At 70 she was having trouble keeping up.
I wish she had lived closer to me, she was a fantastic grandma to our daughter. She gave me hell for 10 years since she thought I was stealing her daughter. All in all I wish she was still alive. Give your folks a call and go see them. It can be too late before you know...
/ Blackberry Menace #8
Harv,
Do you want to keep the blackberries? If not, then as another poster mentioned just use your FEL with the bucket edge floating on the ground and you may be amazed at how easy the blackberries clean out. This works best at the end of the season when the stems dry. I've done this on my property and after removing the first one (it was such fun - of course it is only fun to those who have done it the manual way/w3tcompact/icons/smile.gif) went looking for others to remove! /w3tcompact/icons/smile.gif)
DaveV
/ Blackberry Menace #9
Hey Bird, I saw on Harv's profile that he's been into Martial Arts for three years now. He should be able to handle that strike and slice /w3tcompact/icons/cool.gif Harv, you have been working with that Katana, yes?
Harv, another poster was right on on this subject. Keep you tools sharp. Our wildland gear is always kept sharp, and files are available for sharpening when you're working the fire line. Doing this at home has made a BIG difference when I'm clearing brush.
RobertN in Shingle Springs Calif
/ Blackberry Menace #10
Harv,
Blackberry or raspberry the best way I found to knock them down with out getting torn up /w3tcompact/icons/frown.gif,is a heavy duty weed trimmer with a blade on the end, /w3tcompact/icons/smile.gif
than I chop those little boogers to pieces. /w3tcompact/icons/smile.gif
I did leaves some berry bushes,for I enjoy a couple of had fulls of berry now and than. /w3tcompact/icons/wink.gif
Thomas..NH /w3tcompact/icons/wink.gif
/ Blackberry Menace
Great feedback! Thanks again, guys.
Bird, Del, BSpence, RobertN -
I went out to Orchard Supply today and picked up the one and only machete they carry. It's 22 inches, good edge but not terribly heavy. I'll test it out against the blackberry and let you know how effective it is. Martial arts notwithstanding, these are not skilled hands, so the berries having a fighting chance. /w3tcompact/icons/tongue.gif
DVerbarg -
All tolled, we probably have over an acre of blackberries on the property, so this one stand is forfeit. I will undoubtedly take a whack at it with the loader from above and below, and if I see a chance I'll bring in the DR Trimmer/Mower (might have to use the beaver blade), and then there's always the machete. One way or another, that bush is goin' down. /w3tcompact/icons/mad.gif
Notice I didn't mention the bush hog. Remember, I haven't even hooked it to the tractor yet, let alone know how to use it. I will get plenty of chance to try it out on the tamer parts of the property, but I'm a little concerned (okay, "chicken") to try it out on blackberry with unfamiliar / hidden obstacles underneath. GlennMac's suggestion of backing the mower in without power as a "field test", so to speak, is a possibility. It all depends on how I do with the other methods first.
/ Blackberry Menace #12
Thomas, the first year I was here, and learned from my county agent that blackberries will produce better if you cut out all the old stalks every year, I did use a blade on a heavy duty Stihl weed trimmer. It cuts just fine, but the thorns hold everything together so they don't fall out of the way. It works well for two people; I cut while my brother was pulling them back and rolling them up with a rake. Doesn't seem to me to work worth a hoot if you're alone. And I think you'd have the same problem with the machete. Ideally, you would just cut out the old stalks and leave this years growth to continue, but that would really be a big job. With the brush hog, no effort and the job's done in two minutes.
Bird
/ Blackberry Menace #13
I have on occasion turned around and backed the tractor into those type of brambles with the Bush Hog running. It makes short work of it and you don't have to blindly drive in head first. I do this also when I want to clear an area of small trees that I can't drive in head first.
Chuck
/ Blackberry Menace
Well, the actual battle was sort of anti-climatic. First of all, I decided to make the culvert a few feet further downstream than I had originally planned, so the "menacing" part of the blackberries was only a few feet.
My new machete proved absolutely useless against those tough vines. Since they are unsupported, they just bend out of the way, even if I used that slicing motion that Bird mentioned. A good part of the problem, I believe, is that the factory edge on the blade is only sharp enough to cut butter if it's melted. /w3tcompact/icons/mad.gif When I get a chance, I'll try putting a real edge on it (despite manufacturer's warnings against it) and see if it does any better.
Not to waste any more time on it, I jumped on my trusty 'Bota and just waded in with the bucket high, dropped it to the ground right through the bush and then just backed up slowly scraping the ground with the blade. Not very elegant, but in just a few passes I had enough room to work. One pass with the box blade took most of the remaining vine stumps off at the ground. The few that were too stubborm even for the blade were pretty much shredded by this time, so I just left them.
Oh, yeah -- about not using the brush hog in case there were surprises hidden in the bush? Found a 3-foot boulder just lurking in the briars, waiting for a mower blade.
Not a very photogenic episode, but I took a few snaps anyway.
UNUSED 2023 JCB S4550E ELECTRIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
2021 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2021 Ford F-150...
AUCTION STARTS HERE @ 9AM (A65053)
AUCTION STARTS...
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
Club Car Emergency Cart (A64557)
Club Car Emergency...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
