Black smokeand engine knock at 2000+ rpm
   / Black smokeand engine knock at 2000+ rpm #1
Anonymous Poster
Epic Contributor
Hey everyone,
I've been using my 186D for about 5 months now. I got it just before the big snow in Md. It has a problem. It starts great runs fine below 2000 rpm, but as soon as I throttle up it bellows black smoke and the engine knocks. I changed the oil and it still acts up.Bad fuel maybe ? any help would be appreciated. Thanks Bob
   / Black smokeand engine knock at 2000+ rpm #2
Remember, all you got on a diesel is air, (both in and out), fuel, and compression, so easy stuff first. How about the air cleaner, fuel filter, injector cleaner, drain fuel and start with fresh, Last resort before going inside, Pull muffler off and make sure it's not clogged, test injectors.
   / Black smokeand engine knock at 2000+ rpm #3
Air flow is a strong function of engine speed. Breathing restriction is most noticable at high engine speed. Don't be afraid to run it for a few minutes with the air cleaner off. While you have the muffler off - run it like that too. You can run it without the muffler as long as you want, and can stand the noise!
   / Black smokeand engine knock at 2000+ rpm #4
All the things mentioned so far are good to do. But my feeling is that it's a timing problem. Either valve clearances (.008") cold. Or fuel injection timing (including worn cams or worn pump) or both. Gary J.
2009 VOLVO VNM DAY CAB (A52576)
2009 VOLVO VNM DAY...
2016 JLG 2032ES Electric Scissor Lift, 369hrs (A52384)
2016 JLG 2032ES...
2012 Kia Sorento SUV (A51694)
2012 Kia Sorento...
2018 KENWORTH T370 REAR LOAD GARBAGE TRUCK (A52576)
2018 KENWORTH T370...
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
Genie GTH-644 (A50490)
