Black smokeand engine knock at 2000+ rpm
   / Black smokeand engine knock at 2000+ rpm #1
Anonymous Poster
Epic Contributor
Hey everyone,
I've been using my 186D for about 5 months now. I got it just before the big snow in Md. It has a problem. It starts great runs fine below 2000 rpm, but as soon as I throttle up it bellows black smoke and the engine knocks. I changed the oil and it still acts up.Bad fuel maybe ? any help would be appreciated. Thanks Bob
   / Black smokeand engine knock at 2000+ rpm #2
Remember, all you got on a diesel is air, (both in and out), fuel, and compression, so easy stuff first. How about the air cleaner, fuel filter, injector cleaner, drain fuel and start with fresh, Last resort before going inside, Pull muffler off and make sure it's not clogged, test injectors.
   / Black smokeand engine knock at 2000+ rpm #3
Air flow is a strong function of engine speed. Breathing restriction is most noticable at high engine speed. Don't be afraid to run it for a few minutes with the air cleaner off. While you have the muffler off - run it like that too. You can run it without the muffler as long as you want, and can stand the noise!
   / Black smokeand engine knock at 2000+ rpm #4
All the things mentioned so far are good to do. But my feeling is that it's a timing problem. Either valve clearances (.008") cold. Or fuel injection timing (including worn cams or worn pump) or both. Gary J.
2010 BIG TEX 18 TANDEM AXLE TRASH TRAILER (A52472)
2010 BIG TEX 18...
2025 New/Unused Wolverine Clip on Pallet Forks (A51573)
2025 New/Unused...
2013 FREIGHTLINER M2 ROUSTABOUT TRUCK (A52472)
2013 FREIGHTLINER...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
