black smoke /low power
/ black smoke /low power #1
JOEN
Kubota BX2200
Any suggestions for what is causing loss of power and black smoke when mowing grass on a bx2200. We are not talking high grass. The grass is probably 4 inches tall and dry and I am cutting at about 3 inches. Any suggestions at what to look at would be appreciated. (Air/fuel Filters have been changed.)
/ black smoke /low power #2
Cruddy fuel?, Something living in the gas tank (algae), Something living in the air tube to the air filter?,Brake stuck on?, injector hosed up? That is a few things to check.
/ black smoke /low power #3
Black smoke usually indicates too much fuel or not enough air. Have you checked you air filter?
M.D.
/ black smoke /low power #4
Or...check the mower for binding...black smoke can also indicate the engine's working hard.
/ black smoke /low power #6
tandttravis said:
My bet is the air filter, or some sort of obstruction to the air intake.
Black smoke,low power:dodge-cummins exp. suggests plugged fuel filters Flatfenderguy
New/Unused Wolverine 66in Quick Attach Smooth Bucket (A65583)
New/Unused...
FUEL TANK ON A SKID (A65643)
FUEL TANK ON A...
76in. Skeleton Skid Steer Grapple (A65640)
76in. Skeleton...
2011 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A65643)
2011 TROXELL...
B&W Gooseneck Ball, Unused (A66408)
B&W Gooseneck...
New/Unused Landhonor 24in Semi-Automatic Tire Changer (A65583)
New/Unused...
