BL10 vs BL10A
/ BL10 vs BL10A #1
metalchomper
Westernish NC
Branson 3510
I'm getting frustrated with finding a economical loader for my 3510 (not a 3510i). I've priced a Bush Hog and Koyker loader in the price range of $4300-$4500.
My first option was to build my own. I emailed questions to Cadplans and never got a response. Then I came across a Kubota LA480 loader that needed work for less than the steel would cost. The hydraulics are burned up from a tractor fire. Got it home and and after dissassembly found the frame to be twisted.
Well I finally decided enough is enough and bought a BL10A loader today. The dealer said it would fit. I guess he was wrong. The 3510 has a slightly different bolt spacing on the frame rail as well as lacking a thread block as on the 3510i. The instructions show the BL10 exploded view. This appears to be what I need for the 3510.
Questions:
1. Since my dealer is cloesed until Monday, Is the BL10 readily available? If so, how does the price compare to the BL10A (the dealer would probably have to special order it which I would assume make is more costly)
2. Will the BL10 fit the 3510?
3. I can drill new holes in the BL10A mounting plate and fabricate a front subframe like on the BL10. What is the metal thickness on the front sub-frame?
Thanks,
Brett
2022 WESTERNSTAR 4700 CONCRETE MIXER (A67714)
2022 WESTERNSTAR...
2007 Toyota Rav4 SUV (A66738)
2007 Toyota Rav4...
Skidded Fuel Cell (A67714)
Skidded Fuel Cell...
2022 CATERPILLAR 299D3 XE SKID STEER (A65056)
2022 CATERPILLAR...
2008 FORD CROWN VICTORIA  CAR (A66091)
2008 FORD CROWN...
2015 Ford F-550 4x4 Mason Dump Truck (A66736)
2015 Ford F-550...
