BL10 vs BL10A
   / BL10 vs BL10A #1
metalchomper
Westernish NC
Branson 3510
I'm getting frustrated with finding a economical loader for my 3510 (not a 3510i). I've priced a Bush Hog and Koyker loader in the price range of $4300-$4500.
My first option was to build my own. I emailed questions to Cadplans and never got a response. Then I came across a Kubota LA480 loader that needed work for less than the steel would cost. The hydraulics are burned up from a tractor fire. Got it home and and after dissassembly found the frame to be twisted.
Well I finally decided enough is enough and bought a BL10A loader today. The dealer said it would fit. I guess he was wrong. The 3510 has a slightly different bolt spacing on the frame rail as well as lacking a thread block as on the 3510i. The instructions show the BL10 exploded view. This appears to be what I need for the 3510.
Questions:
1. Since my dealer is cloesed until Monday, Is the BL10 readily available? If so, how does the price compare to the BL10A (the dealer would probably have to special order it which I would assume make is more costly)
2. Will the BL10 fit the 3510?
3. I can drill new holes in the BL10A mounting plate and fabricate a front subframe like on the BL10. What is the metal thickness on the front sub-frame?
Thanks,
Brett
2011 Chev Impala (A51694)
2011 Chev Impala...
2013 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2013 FORD F-150 XL...
PLEASE VIEW ALL PICTURES!! (A50775)
PLEASE VIEW ALL...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
Case SV185 Compact Wheel Loader Skid Steer (A51691)
Case SV185 Compact...
