BISQUITES & GRAVY -- COOKING
/ BISQUITES & GRAVY -- COOKING #41
After reading all the good biscuits and gravy stuff, I had to make some for supper. My gravy didn't turn out to good. I lost the know how, but you just wait until next time i'll get it right. This might also go with the biscuits and make you show your teeth from the smile on your face.
Turkey Recipe
8 - 15 lb. turkey
1 cup melted butter
1 cup stuffing (Pepperidge Farm is Good)
1 cup un-popped popcorn (ORVILLE REDENBACHER'S LOW FAT IS BEST)
Salt/pepper to taste
Preheat oven to 350 degrees. Brush turkey well with melted butter, salt,
and pepper.
Fill cavity with stuffing and popcorn. Place in baking pan making sure the
neck end is toward the front of the oven, not the back.
After about 4 hours listen for the popping sounds.
When the turkey's butt blows the oven door open and the bird flies across
the room,.... it's done.
/ BISQUITES & GRAVY -- COOKING #42
I have a couple of the newer Lodge cast iron skillets. They are "pre-seasoned". As near as I can tell, the skillet cooking surface is left with an un-ground cast surface, very fine bumps. Then they season it with soybean oil in an oven. My old cast iron skillets that were my Dad's have the cooking surface ground flat. There is just no comparison between the new and old for non-stick cooking, the new is 20 times better and a lot easier to keep seasoned as long as you follow the directions and keep the soap away from it.
I have never used the "Pre-seasoned type". If you purchase a regular piece of Lodge Cast iron cookware, and season it it the oven on 350 degrees, with several applications of Crisco or bacon grease, you will be surprised. I have seasoned many a regular piece for others. Just a thought.
/ BISQUITES & GRAVY -- COOKING #43
I'm not sure that "pre-seasoned" business means much. Quite some time ago, I bought two of the Lodge Divided Rectangular Mini Servers. Now admittedly, I bought them for a different use than what Lodge says they're for. The two of them lets me bake 6 pieces of cornbread in a shape and size that I really like. But I had a terrible time with my cornbread sticking. I tried using a cooking spray, olive oil, re-seasoned them according to instructions I found on the Internet. Anyway, I FINALLY solved the problem. When I make cornbread, I first put a little bit of real lard in each division, pre-heat and melt the lard in the oven before putting the cornbread batter in them, and afterwards, I just wipe them clean with paper towels.
/ BISQUITES & GRAVY -- COOKING #44
My cornbread cake barely drops out of my medium Lodge pan under its own weight, so I can see who the divider might make it less likely to do so. If I ever have any issues, I will try to remember the lard trick.
Now I know why biscuits are sometimes called "Sinkers".
Got 1/2 my propane problems solved. Now is time to make some biscuits.
Grated frozen "Fake" butter into mix. A little extra baking powder, all stirred together. Add recommended amount of milk , not enough still a little dry, add more. Still a little dry, maybe that the way they spose to be. ??? Even broke out the rolling pin.
They cooked up nice & fluffy (for biscuits). Tasted good. Ate 1 with butter soon as taken from oven. A little crumbly ( should have added a little corn starch & an egg.) in the batter.
Had another with butter & honey. Good taste.
Though I would lay down for a little while. Gone for 4 hours, wild crazy dreams. My new sleeping pills. cartoon020.png
/ BISQUITES & GRAVY -- COOKING #46
I have seasoned the old style as you describe. I think the main difference is in the texture of the cooking surface for the new type. You still have to keep the surface seasoned a bit.
I cleaned up some very old and well used Wagner cast iron skillets. They had a hard shell "seasoning" layer on them, then rusty gunk underneath that. It didn't look too appetizing :eek:
I assume these skillets were used day-in day-out for many years. I actually tossed one in a fire to get it clean, the seasoning layer was so hard. I don't know, not much experience, but my guess is that on a well seasoned skillet, the food never touches cast iron.
UNUSED RAYTREE REDM32 HYD MULCHER (A60432)
UNUSED RAYTREE...
UNUSED SUCTION CUP WINDOW GRABBER HANDLE (A60430)
UNUSED SUCTION CUP...
2010 MULTIQUIP 25KW GENERATOR (A58214)
2010 MULTIQUIP...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
2019 PJ TRAILER 32FT GOOSENECK (A58214)
2019 PJ TRAILER...
UNUSED KJ K4230W-42'X30' METAL STORAGE SHED (A60432)
UNUSED KJ...
