Bison 650 operating RPM's
   / Bison 650 operating RPM's #1
pretzelb
Central Michigan
Bison 650
Hello,
I recently bought a Satoh Bison 650 with a 5ft snowblower. I have been using it also to run our wood splitter off the PTO@540 around 1800 RPM's which works great. I have been told that when I run the snowblower I should run it around 2800 RPM's..That sure seems like high RPM's for that..What do you guys run your PTO attachements at ? I dont want to stress the motor by revving it up too much. Any opinions would be welcomed.
Brian
   / Bison 650 operating RPM's #2
Welcome to TractorByNet :welcome: Tractors were never designed to be "babied" so I wouldn't worry about it much. Running things too slowly can bring their own issues. If the snowblower is designed for a 540 rpm input then you should run the engine at a speed that produces that at the PTO. If you are satisfied with its performance at lower speeds, then by all means do that if you prefer it, but I wouldn't avoid running things at their designed speed because it "stresses" its components. 2800 rpms is not significant for a typical gasoline engine or even a diesel for that matter. It looks like it's the design speed of the engine so you shouldn't have any worries.
   / Bison 650 operating RPM's #3
I's second that first reply. Although if you can get verification that the snow blower is supposed to be running that fast I think I would ( an operators manual perhaps).
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
2017 Big Tex 10ET T/A Flatbed Equipment Trailer (A50322)
2017 Big Tex 10ET...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
Anderson 31ft T/A Flatbed Equipment Trailer (A51691)
Anderson 31ft T/A...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
RING 2 STARTS HERE @ 9:15 AM (A54756)
RING 2 STARTS HERE...
