Dadnatron
Veteran Member
I purchased a Hobart 210 MVP and I have been having a lot of birdnest issues at the drive wheels.
Hobart .035 flux core
Orientation is correct.
I've insured I am using the knurled groove.
I've set tension tight, loose, 'appropriate according to manual', 'finger stoppable at gun tip'... all seem to make little difference.
Occurs at all wire speeds I have used over about 30 (which I believe is 300ipm)
Its intermittent. I can weld for 20 min without a problem, and spend the next hour fixing several birdsnests in a row.
I'm liking this little machine less and less. I purchased it at TSC, and I am thinking about taking it back. The other bigger issue for me is the lack of adjustability. I have 7 power settings which don't relate to anything specific that I can tell. I just know up is hotter and down is colder. I'd like to see what V and Amps they actually represent so I can learn what I am doing better.
If I can't get this birdsnest issue fixed, then I will definitely be taking it back.
