Bill from the Mill
   / Bill from the Mill #1
wsjones
Mahomet, Il.
Cub Cadet LT1050
Cadet LT1050 won't start. Charged battery. Solenoid just clicks. Will try jumping right to positive sterter post tonight. Hope it cranks.
It did turn over with direct jump. Bad solenoid?
   / Bill from the Mill #5
Probably a bad solenoid or a bad "trigger" connection to the solenoid.
If you run a jumper wire from the large "battery" terminal on the solenoid to the small "trigger" terminal, does it crank?
Aaron Z
   / Bill from the Mill #6
Welcome from Erie PA tonight.
Put in a new solenoid last night. Fired right up! The old one was leaking some tarry stuff. Good to go for another season.:cool2:
Jumper Cables (A53316)
2005 CATERPILLAR 740 - 6X6 OFF ROAD WATER TRUCK (A52706)
2005 CATERPILLAR...
MMS MS380R (A53316)
MMS MS380R (A53316)
Kivel Pallet Forks (A53316)
Kivel Pallet Forks...
2018 Ford F-150 Ext Cab 4X4 Pickup Truck (A55788)
2018 Ford F-150...
