Bigger bucket for KL130
   / Bigger bucket for KL130 #1
gippolit
New Jersey
CK30HST Loader Backhoe
Can I get a bigger bucket for a KL130 loader??
Thanks
Glen
   / Bigger bucket for KL130 #2
60" is the biggest from Kioti, but if you adapt it to the QA setup then the sky is the limit on size. ATI makes a Universal QA plate for the loader then that would allow you to use any standard QA bucket, I would stick with the 60" though in order not to over load it, 66" at the max.
Jon how much is a qa setup?
Thanks
glen
   / Bigger bucket for KL130 #4
I wondered why they didn't make the bucket bigger. The 60" length is enough but I wish it was deeper or wider. Mine is on a CK30. I had it full of 2B gravel, sand, and dirt and it lifted with no problem. Carrying was no problem as long as you kept the bucket low which should be done anyway.
The QA would be nice as Jon mentioned. More money. Maybe next year. BH is next in line.
   / Bigger bucket for KL130 #5
I sell the quick attach for $549.00 it is a HLA product.
   / Bigger bucket for KL130 #6
</font><font color="blue" class="small">( I wondered why they didn't make the bucket bigger. The 60" length is enough but I wish it was deeper or wider. )</font>
The R&D department decided that the buckets should be 60". In the past, the CK20, and others, had a range of buckets offered, but they decided on a size in the middle of the range because they felt the larger buckets were oversized for the tractors.
I suppose this came from damages that were repaired under warranty, or just that the engineers revisited the issue and realized they were overstressing the loader arms. Either way, what they sell is what the engineers recommend one use.
John
2016 BOBCAT T550 SKID STEER (A52709)
2016 BOBCAT T550...
2015 MACK CXU CONVERTED TANDEM AXLE DUMP TRUCK (A58017)
2015 MACK CXU...
ST205/75R15 Trailer Tires (A55788)
ST205/75R15...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
UNUSED FUTURE...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
