radman1
Elite Member
- Joined
- Jul 8, 2006
- Messages
- 3,017
- Location
- midwest
- Tractor
- JD 4520, Toolcat 5610, Bobcat S300, Case-IH 125 Pro, Case-IH 245, IH 1086, IH 806
Has anyone considered putting a larger boom cylinder on the TC? The current one is 3000 psi, welded, 2.5" bore, 1.5" rod and 22.89" stroke. I am considering putting on a 3000 psi, welded, 3" cylinder with a 1.75" rod and 22.75" stroke. The new cylinder is about .75" longer retracted but I can cut a little off of the base end to make almost the same length. However, the 3" cylinder will push about 50% more force. I am correct in assuming if the TC can lift 2000 lbs currently (although rated for 1500#), it will now lift nearly 3000 lbs with the 50% increase in force?
