BIG Ooops!!!
   / BIG Ooops!!! #1
BrentD
Boy did I screw up today. We got the first nice weather day we've had in weeks so I decided to take our little BD2G dozer out and do some work on the pond I'm rebuilding. A lot of sand washed in over the years so I still need to take the deepest part down another 4 feet or so. Anyway, I drive out into what is currently a sand pit (until the dam gets rebuilt ) and notice a couple of smallish puddles of water, probably left over from the 2" of rain we had last weekend. I took everything slow to make sure the dozer could handle the slightly damp sand, and everything seemed to go just fine. The dozer had LGP tracks on it and the sand barely gave when I crossed it.
So, thinking everything was good, I started to dig. The sand was actually cooperating with me today and I felt like I was set to make some real progress. In about 5 minutes time I had a pretty good area cut down about 3 feet and was in the middle of making a final pass through the area when I noticed that the sand in front of me was not longer behaving right. There was suddenly an awful lot of water in the hole with me. I quickly raised my blade to dump what I was pushing and was going to high-tail it out when the dozer stopped moving forward. I looked down at my tracks and they were coated with the nastiest grey gumbo I've ever seen. And to make matters worse, the puddle I noticed on the way in were now mostly dry. All the water had seeped through the sand down to where I was working.
The grey goo is what is left of the muck that used to be at the bottom of the original pond before the dam broke and 4 feet of sand washed in over the top of it. It makes a nice seal to hold the water in. We borrowed a friend's trash pump to try to pump the water out of the hole, but the pump gave out on us after just a few minutes. We tried hooking two tractors to the dozer and trying to pull it out, but it just buried the front end that much deeper.
The front of the tracks are covered over with mud and the mud is about level with the center-line of the rear driver sprocket. Since we ran out of time this evening I'm planning to make a run to Tractor Supply in the morning and buy another trash pump. If we can get the water out of the hole, we may be able to get things dry enough to get something under the back of the tracks and get enough traction to back the dozer out. It just happens to be in an awkward position where a larger machine wouldn't easily be able to get to it to pull it out. There's no way it's going forward at this point either. Even with the blade raised all the way it's now sitting on the dirt. If we could move it even a couple of feet it would be back on ground that is solid enough to give it enough traction to pull itself out.
Anyway... This probably isn't directly safety related but I couldn't see that it fit anywhere else. I guess it does fall into the category of machine safety rather than operator safety.
So, any suggestions on how I might go about getting this thing out? We're supposed to get another storm coming through on Tuesday and could get another 2-3 inches of rain, which would probably fill the hole up so far the water would be over the seat. I'll try to remember to take pics tomorrow.
   / BIG Ooops!!! #3
Attach a rope / chain to the back of the treads and tie it off to a tree or maybe a truck. Then back up... VERY SLOWLY. might work. Poor mans way.
   / BIG Ooops!!! #4
Oooo---:eek: Sounds like tank retreiver time.... Good luck- that can be hard! Had an M-48 stuck to about mid-track once; snapped two 1" steel cables before we got it out... (Course, we were young & stoopid then....)
   / BIG Ooops!!! #6
I might do a few more tries, but there comes a time when we need to call in the professionals, or rent something huge to pull it out. Unless we have a friend with the right equipment.:cool:
   / BIG Ooops!!! #7
Pictures are a must. Sounds like a dirty job :rolleyes: Good luck on getting it out before more rain. Dozers are some of the hardest one to pull out due to the tracks having a lot of surface area for the mud to cling to. So you have alot of suction to overcome.
   / BIG Ooops!!! #8
Dirty Job? Great idea! Brent you should call Mike Rowe, he will come and dig it out for you!
Free of charge AND we will get to watch on TV!
j/k, I feel your pain, good luck getting it out...TAKE PIX!
   / BIG Ooops!!! #9
Any possibility of dragging some long poles . . say 4"or 5" wooden poles, longer than the machine is wide to the back end of the crawler?and back up on them. It's a tough job to do but it works , did it numerous times. If you have any soft wood trees around lay the branches down heavily first then the poles and you will be very suprised what happens. It is like a pair of snowshoes in the snow. Good luck, and I hope your out before you read this. . .John
   / BIG Ooops!!! #10
As mention working wood or poles under the track can work. I have done it on much bigger dozers than that and got them out. If you can lift the tracks with blade downpressure you can work long poles/timbers/tree trunks under the front to give you a solid base. I buried a D6C and still have telephone poles buried out in the middle of a field from doing that. They sank so far there was not getting them back if I wanted to. After sitting overnight suction may really be strong on the belly pans ect. Good luck.
2019 VOLVO VHD84F300 TRI-AXLE DUMP TRUCK (A51222)
2019 VOLVO...
1973 CATERPILLAR 988 LOADER (A51222)
1973 CATERPILLAR...
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
2020 CATERPILLAR 326 EXCAVATOR (A51242)
2020 CATERPILLAR...
2021 Interstate Tiltbed 40TDL 24 Ton T/A Flatbed Trailer (A49461)
2021 Interstate...
VOLVO L45G WHEEL LOADER (A51242)
VOLVO L45G WHEEL...
