Big enough AND small enough
   / Big enough AND small enough #1
Highsmith
Bronze Member
Kingsbury, TX
Kubota L2350DT, BCS 853
   / Big enough AND small enough #2
I think that would work - or a JD 5525, which is roughly the same size. Maybe a JD 5603 to get a cab and 99 PTO hp with about the same physical size?
Not sure how many post holes you're planning to dig, but if it's into the 100's or 1000's I would be thinking of a skidsteer or power-trac for speed and precision.
   / Big enough AND small enough #3
If you have a lot of posts to do think about a post driver instead . quicker and better. If you are going to use it for planting that's a different story.
   / Big enough AND small enough #4
You could always get a QA and a hydralic QA mounted post hole digger. I think it is a little easier to use when up front and you get down pressure.
   / Big enough AND small enough #5
I am not sure internal hydraulic pumps have enough flow for the hydraulic motors on Skid steer attachments. Maybe the bigger ones.
   / Big enough AND small enough #6
Skid Steer Attachments - Quick Attach Attachments, Inc.
Two models available 10 gal/min to 25 gal/min and 15 gal/min to 30 gal/min
if he is looking at 90+ hp it should be able to handle it.
JD 5525 -- 25.3 GPM
JD 5603 -- 22.5 GPM
TT75A -- 19.3 GPM
   / Big enough AND small enough #8
If you do go for a high hp utility.. make sure you have the weight to handle the hog.
Good luck.
Soundguy
INOP/NON-RUNNING Chevrolet Rollback (A51572)
INOP/NON-RUNNING...
UNUSED HURRICANE D6028 JOB BOX (A51248)
UNUSED HURRICANE...
2015 Ford F-150 Pickup Truck, VIN # 1FTEW1EFXFFA41510 (A51572)
2015 Ford F-150...
2014 Club Car Electric Utility Cart (A51694)
2014 Club Car...
New Holland LX865 Skidsteer (A51573)
New Holland LX865...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
