Big drill bits
   / Big drill bits #1
fatjay
Veteran Member
Eastern PA
Not enough
I'm looking for a set of good oversized drillbit, ¾, ⅞, 1", 1⅛, 1ï½¼,1⅜, 1ï½½. Amazon's got them up to 1" but the reviews aren't great and honestly that's the only place i shop aside from harbor freight and home depot. I'm drilling into ¾" 67 year old steel, the last time i did it, i burned through 2 drills and it took an hour. That was a $40 1" bit.
   / Big drill bits #2
I have one of the 1/2"-1" in 64ths that has drilled a lot of holes (all in a drill press or mag drill). It was in the $60 range 7 years ago. I have never seen a set of ones over 1". I buy individual ones as I need them. Up to 1/2" thick stock I use a hole saw or torch. You can spend a lot of money on good drill bits. I have a separate set of 1/16-1/2 in 64ths I use exclusively on the drill press.
Ron
   / Big drill bits #3
I don't know how many holes you need to drill or if the holes need to be perfectly sized, but I usually use Milwaukee metal hole saws and the green stuff "West Lube" lubricant.
I use slow speeds, medium pressure, lots of the green stuff, and clear the spoils out of the hole as often as necessary while drilling.
I have 5/8" and 3/4" drill bits, and when I need that size hole, I always use a hole saw.
For me, the slightly larger hole that a hole saw makes is ok.
Good Luck, KC
   / Big drill bits #4
depending on how perfect you need hole's plasma or torch is always faster .:drink:
   / Big drill bits #5
I used to work in an agriculture implement factory, and the biggest conventional twist bit we had was a two and half inch. All the bigger ones were taper shaft `Blacksmith` Blacksmith to me means, the drive shaft is smaller than the actual cutting edges.
   / Big drill bits #6
I am an experienced handy man that hasn’t used metal until I purchased my tractor. An early lesson was to use step bits when drilling holes in metal. Once I learn you can’t push your bit through metal everything is working well now. You can pick up step bits at a Canadian Tire almost every other sale for 70% off. The key is to use a 1/8” pilot hole.
   / Big drill bits #7
I tend to use hole saws for anything 3/4" and above.
Are you drilling free handed or with a press?
   / Big drill bits
I have a few big bits, but no one stocks them so they're all special order. Which means I have to wait for shipping. I have a metal hole saw bit i used once for a 1½" hole but it was a real bear.
I am buying a new bucket for my backhoe and pin sizes may not match, but I don't know what I need yet. I will likely pick up the bucket this weekend, then I'll have to wait for bits to drill, I was just thinking it would be nice to have a few standard sizes on hand.
   / Big drill bits #9
After spending $40+ for one drill bit over 1" - I went to hole saws. Clamp the work well - hole saw and my Milwaukee Hole Hog. Hold the side handle on the "up wind" side or be prepared for some serious shin bumps if the hole saw binds. I really prefer the drill press if the work will fit.
I keep the operation lubed with chain saw oil.
   / Big drill bits #10
I'm thinking this is 'tools' rather than 'attachments', but .....
I'll go along with start small and work up, step bit or not. 1/2" bits are lest costly. Use them for pilot holes, then progress to 3/4" or whatever.
2011 Ford F-150 Pickup Truck (A50323)
2011 Ford F-150...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51243)
UNUSED X-STAR 101"...
TC710 FINISHING MOWER (A50459)
TC710 FINISHING...
Pull-Behind Smooth Drum Ballast Roller (A51691)
Pull-Behind Smooth...
