tallyho8
Super Member
- Joined
- Aug 1, 2004
- Messages
- 5,252
- Tractor
- Kubota L4400, Kubota ZD326
Dealers today want to insure that they do not get a "call back" on a repair job. "Call backs" cost them money and are bad for customer relations. They cure this problem by replacing all components of a broken system to insure that another worn part will not break during the warranty period causing a "call back". Unfortunately, this is an expensive procedure for the customer and some may want to seek alternative repairs from another repair shop that will only replace parts that are already bad.
Examples: If your power steering pump goes bad, they want to replace the pump, both hoses and belt. If any part breaks in your transmission they want to rebuild it. If a valve starts leaking they want to rebuild the heads. (or the whole motor) If your brake pads are worn they want to replace the pads, cylinders, rotors, etc.
Many people who can afford it agree to this type of "preventive maintenance" but those on a budget generally prefer to only replace the broken part and risk further repairs later.
