Bh77
   / Bh77
I called messicks, the salesman wasnt sure if the subframe kit included the hydraulic hoses/ends,,, he said it didn't say needing anything else, but he wasn't sure,, I probably will double check with another dealer
   / Bh77 #12
When they say the sub-frame kit includes the "mounting kit", I believe the mounting kit has the hydraulic hardware, but you should check with your dealer to be sure.
I wouldnt count on the subframe having the hydraulics.
You mentioned adding 2 spools... I'm pretty sure Kubota taps into the power beyond loop. The hoe gets plugged into that loop & when its unmounted a jumper hose is used to keep things flowing.
You could plug into the ports on a spool. But the OEM spools for the Ls aren't detented (the OEM valves for the grands just stuck & leak internally by the way). You could just use a bungee cord to hold the un-detented valve open to make the hoe work. A little bit redneck looking , but functionally a perfectly serviceable option. That's the route I would go to avoid messing with power beyond plumbing.
http://www.tractorbynet.com/forums/hydraulics/295816-kubota-l3200-tnt-3rd-function.html documents my hydraulic project on my former L3200. Those valves from FitRite weren't cheap, but were nice. The dealer has replaced the rear valves on my new L4060 several times & the best of those valves isnt nearly as good as those Butchers.
Both subframe kits that I bought (B3200 and L3240) came with everything including the hydraulic connections.
Correct, use a jumper hose when the backhoe is removed which keeps your pump from deadheading.
   / Bh77 #13
FYI... You might have called the wrong department, Parts. Wholegoods is through the sales department. The info I provided earlier was Wholegoods and not sold through parts.
15 35ft. Commercial Black Metal Light Poles (A56858)
15 35ft...
SKID STEER ATTACHMENT TILLER (A58214)
SKID STEER...
10' CONTAINER (A52706)
PJ  32 FLATBED GOOSENECK (A58214)
PJ 32 FLATBED...
New/Unused Mini Crawler Dump (A57453)
New/Unused Mini...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
