BH77 with BXPANDED Quick-On
/ BH77 with BXPANDED Quick-On #1
bandit67
Lake Hartwell, SC
2012 B3000 HSDCC 2020 Z251 Zero Turn
Just installed my new BXPANDED Quick-On. Could have used this years ago. Swapping between the bucket and the MI&E ripper was a complete pain before the Quick-On, especially with having to line up the thumb, so I'm looking forward to getting a whole lot more use out of the ripper now that it is so ridiculously easy to do the swap.
/ BH77 with BXPANDED Quick-On #2
Yep, I've had mine for about 3 years now. I would never go back. Only issue I've had is loosing the keeper pin, I keep a couple of extras on the tractor or sometimes use a bolt and nylock nut. Yours lloks better than mine though since they now offer it in orange, mine is silver.
/ BH77 with BXPANDED Quick-On #3
I just got mine 14-July, they didn't offer it in orange when I ordered mine.
This one has been in the works for a few months. It was customized a bit because my ripper pin spacing is 3/4" further than the pin spacing on the factory buckets, so the Quick-On was beefed up to handle the further spaced ripper's rear pin sitting out closer to the end of the slot. I also asked if they could do it in orange for me - sometimes you just have to ask. :thumbsup:
/ BH77 with BXPANDED Quick-On #5
When I purchased mine 3 years ago I just painted it Kubota orange to match.
/ BH77 with BXPANDED Quick-On #6
I bought one too a couple years ago. It would not work with my MIE ripper and I had a local shop modify "ears" to fit by same 3/4". So you asked bxpanded to adapt their QA to accept MIE ripper as made? Good call on your part!
A couple things compromised with my QA are you lose full 180 degree bucket rotation a bit and the bucket is a little sloppy vs factory pins. Is this ame with your version? I would have just went with bxpanded ripper at the time if I was aware of it. But as stated, trade off in time/hassle worth it.
Yes, typical with any backhoe QA is an extra bit of slop, even on big machines. I didn't seem to lose any bucket rotation that I can tell, but part of that could be the factory thumb may have already cut off a slight bit of rotation. Overall, I'm very pleased with the new setup.
/ BH77 with BXPANDED Quick-On #8
I got one for my BX23S, so I could swap between the bucket and BXpanded ripper. It literally takes about 30 seconds to swap it out. Makes it easy when I am in the woods digging out stumps.
/ BH77 with BXPANDED Quick-On #9
You guys that have had this for a while. Does it have much free play? And how is holding up? I’m thinking about ordering this for my Kubota l3200 with the bh77 backhoe.
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
Stout Brush Grapple 66-9 (A66285)
Stout Brush...
Landhonor Quick Attach Seeder (A66285)
Landhonor Quick...
2014 FORD F-350 SUPER DUTY (A65643)
2014 FORD F-350...
2018 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A65053)
2018 CATERPILLAR...
2010 Case 580N (A60462)
2010 Case 580N...
