BH77 backhoe vs KX008 Tiny-Mini Excavator
/ BH77 backhoe vs KX008 Tiny-Mini Excavator #21
Disable the seat safety and use the CC lever to drive the machine forward.
/ BH77 backhoe vs KX008 Tiny-Mini Excavator #22
I dont think the L2501 has the CC lever does it? If I recall the Grand Ls do, and I know the Ms do. On the M62 they have a handy "creeper" lever....so I can raise the downriggers, inch forward a bit, put them down, and keep digging. It is actually pretty fast. For digging in a straight line it is awesome.
/ BH77 backhoe vs KX008 Tiny-Mini Excavator #23
Yes, the hydro economy L’s have cruise as an option.
Okay I get it....:confused3: So you can reposition down the line without swiveling around the seat. My L2501 has a cruise lever. If I pull it, the forward pedal depresses without my foot and the tractor will move forward.
/ BH77 backhoe vs KX008 Tiny-Mini Excavator #26
Many TLB's have an 18 foot reach.
I’ve got a full size backhoe and it would eat the 1 ton mini for lunch or carry 3 of them in the front bucket, but a BH-77 and a 310 is a substantial difference.
/ BH77 backhoe vs KX008 Tiny-Mini Excavator #27
18 feet? That would be on a pretty big tractor I would think. The BH reach on my tractor is only 10'.
How do you use cruise control work with the backhoe?
Move REALLY slowly and dig REALLY fast?
And raise the back wheels off the ground with the BH outriggers when you want it to not move?
I've seen a video of a guy with a JD 1025 who moved the machine forward by raising the outriggers and pushing with the backhoe. I assume the tractor was in neutral. Don't know if that is a recommended method though. Might be a lot of stress on the BH.
/ BH77 backhoe vs KX008 Tiny-Mini Excavator #28
I suppose you could take the lift the wheels off the ground approach but the cc lever was reachable from the backhoe seat. Driving forward was a lot faster then pushing with the backhoe.
/ BH77 backhoe vs KX008 Tiny-Mini Excavator #29
I'll need to find out how the CC works on my tractor. Haven't done anything yet that would benefit from CC. I have ASSUMED that it works the same as on my little garden tractor - get to speed and while still pushing on the go pedal press the CC lever. Not something that would be beneficial in a trench digging operation.
/ BH77 backhoe vs KX008 Tiny-Mini Excavator #30
The one on my L3240 was a lever in the same place and opposite side as the 3 point hitch control lever. You didn’t have to touch the lever and just moved the lever to move forward. It didn’t have reverse which was a slight drawback.
/ BH77 backhoe vs KX008 Tiny-Mini Excavator #31
I checked the manual, my Mahindra CC works the same as the one on the garden tractor.
/ BH77 backhoe vs KX008 Tiny-Mini Excavator #32
My L3240 was an electric controlled HST where economy series tractors are usually linkage. I doubt they work the same way.
/ BH77 backhoe vs KX008 Tiny-Mini Excavator #33
If you are just digging 1 reasonably small hole & not needing to reposition the machine, both will dig based on the machine weight. The excavator is going to excel at digging & moving. But you are only digging 1 hole, so not really digging & moving simultaneously. A tired machine will literally drive circles around an excavator. The excavator is going to be a rough ride topping out at 2mph while the tractor is cruising at 15mph or so.
Presumably you wont be unloading the excavator right at the digging spot. So it will be a slow treck off the trailer to the dig spot(s). Then you sit In 1 spot digging a small hole. Possibly repeating that after moving a fair ways. The excavator will dig better, but I'm guessing you'll spend more time driving with either machine than digging. In which case the tired machine wins.
Not to mention the extra maintnance of another machine.
/ BH77 backhoe vs KX008 Tiny-Mini Excavator #34
I have a kubota kh-41 about 3,300lb machine. I wouldnt want to go much smaller. Mine is about 38in wide and very un stable on the side and travel is slow. With that being said theres nothing more nimble than a small excavator. Being able to go backwards, forwards and even swing 360* in any direction while goiing backward/foreward saves a ton of time. My boom pivots so i can dig right up against a building.
I have no problems digging holes with this machine. I also have an auger attachment for it.
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
2007 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2007 Ford F-150...
iDrive TDS-2010H...
SWICT 78" SKID STEER BUCKET (A60430)
SWICT 78" SKID...
2012 AMERITRAIL (A55745)
2012 AMERITRAIL...
