BH75 owners. Does your hoe look like this?
   / BH75 owners. Does your hoe look like this? #1
MDM
Platinum Member
East Ohio
Kubota L2800HST
Please look at the pics below. It appears that the dipper cylinder runs up the boom slightly off center. Especially when you look at the V shaped plate under the rod.
Also, see the 2 shims at the top with the arrows. Does everyone have a shim on each side? The reason I ask: In the second picture, where I have the vertical line drawn, there is VERY little clearance between the fitting and arm when the hoe is completely extended. It actually made a very light impression on the nut when I extended the arm to max reach.
I'm thinking if I move the shim on the right to the left side, this would help me get more clearance on the fitting and straighten up the cylinder so it is running completely vertical up the boom.
If everyone else's looks like mine, then I'm not going to worry about it.
   / BH75 owners. Does your hoe look like this? #2
I have the "Woods" BH80-X and it does not have any "Shims" on either side,
Production / Assembly quality or ???? for your unit as to a Kubota Hoe????
Jw5875
   / BH75 owners. Does your hoe look like this? #3
Check with the dealer.:D
In my opinion it should be centered.:confused: :confused:
Well, the parts manual shows the shims on each side, so I guess I will leave them where they are at. As far as the cylinder appearing offcenter to the boom, it seem to work fine and everything is snug, so I will live with it.
   / BH75 owners. Does your hoe look like this? #5
Jw5875
Have you had any problems with your BH 80 X????
New Holland L225 Skidloader (RIDE AND DRIVE) (A50774)
New Holland L225...
Bobcat B950 Skidloader Breaker (A50774)
Bobcat B950...
John Deere 4000 Tractor (RUNS) (A50774)
John Deere 4000...
2015 International DuraStar 4300 Johnston VT651 Street Sweeper Truck (A50323)
2015 International...
Polecat Swift 206R 20ft Towable Boom Lift (A50322)
Polecat Swift 206R...
100 gal Water Tank (A50515)
100 gal Water Tank...
