BH75 Backhoe Question
/ BH75 Backhoe Question #1
RobbieBones
New York
Recently I replaced all the hoses on the backhoe. While doing so I removed the Boom cylinder (the one inside the boom) to install new lines. Before reinstalling it I wanted to test the connections for leaks. I was told that I could start the tractor and test the cylinder while it was on the ground without having all the lines connected to the valve controller. I was told that i would not loose any fluid or very little if any would drip out of the ones not connected. Well that sure wasn't the case. Fluid shot out of the valve that controls the dipper and bucket a good 15 feet.I quickly checked to see if the valve was in the neutral position. I could not get it to close/stop. the other valves did not leak. Is that normal or is there a problem with that one valve?
2001 Sea Ray 180 (A61569)
2001 Sea Ray 180...
Cat CB24B (A60462)
Cat CB24B (A60462)
2017 Ford Explorer AWD SUV (A61569)
2017 Ford Explorer...
New/Unused Landhonor Adjustable Gantry Crane (A61166)
New/Unused...
CAT D5G LGP DOZER (A58214)
CAT D5G LGP DOZER...
2021 CATERPILLAR D3 CRAWLER DOZER (A62129)
2021 CATERPILLAR...
