Backhoe BH75 Backhoe Dipper/Bucket Not Working ?? Pic/Video
   / BH75 Backhoe Dipper/Bucket Not Working ?? Pic/Video #11
I almost said to move the TPH lever in different possitions and test. Not a Kub owner but, the issue seemed the same as what I've experience on my MF. When new to your tractor, you feel pretty dumb but relieved when it turns out to be somthing silly like this.
   / BH75 Backhoe Dipper/Bucket Not Working ?? Pic/Video #12
the three point lever should be in the middle not in raise or lower positions there is a priority valve and the 3 point is first user then the loader/ back hoe.
tom
   / BH75 Backhoe Dipper/Bucket Not Working ?? Pic/Video #13
My BH75 works when the 3pt lever is up or down, I don't see where this is a problem. I leave it in the up position normally.
The OP may have lost a bolt attaching to the control lever causing this problem, the locking nuts have alot to be desired, I installed different bolts and locking nuts on mine to cure that problem.
   / BH75 Backhoe Dipper/Bucket Not Working ?? Pic/Video #14
It looks from your video like you are not getting hydraulic fluid to the cylinder. Either you have air in your hydraulic lines or the fluid levels are low. You should recheck your hydraulic fluid level.
2007 NEW HOLLAND B95 BACKHOE (A52709)
2007 NEW HOLLAND...
Terms & Conditions of (Buying through EquipmentDealz Auction) Continued (A59213)
Terms & Conditions...
NEW Wolverine 36in Skid Steer Grapple Bucket (A59000)
NEW Wolverine 36in...
2021 CAT SKID STEER (A55973)
2021 CAT SKID...
2006 Ford Taurus SE Sedan (A54815)
2006 Ford Taurus...
2022 Brush Wolf 4800X Severe - Duty Excavator / Backhoe Brush Cutter (A57024)
2022 Brush Wolf...
