BH6500 Load Check Valve
   / BH6500 Load Check Valve #1
Pj-in-Va
I have a Woods BH6500 backhoe and am trying to identify which load check valve controls which function. Does anyone have a JPG or a PDF ?
   / BH6500 Load Check Valve #2
See pages 24-25 of the Owners Manual linked on this page: Product Details (Woods BH65)
There's a "load check valve" between the control valve working ports for every DA cylinder's ports, can't you just follow the hoses from the port pair adjacent to each LCV to see which cylinder / function it serves (i.e. trace the hoses to see the control valve port assignments) or even easier just see what moves when you actuate the lever on each section of the control valve and look at the LCV aligned with that lever?
Noting that these LCV's only serve to prevent cylinder drop while the spools are intentionally actuated in the brief transition between pressuring one port and pressurizing the other for a given cylinder - they are not to be confused with "load hold valves" which, if you have them, would be external to the control valve and serve to prevent cylinder drop over time absent any intentional control valve actuation (or the neutral position leakage rate spec'd for the control valve).
IF you have the latter, they should be obvious as a fitting or 'block' between the control valve and the cylinder they "hold" .... again easily determined by just following the route of the hose to the cylinder (and function) they serve to "hold".
If I'm missing something in your question, please accept my apology and perhaps try restatement to explain more clearly what you're looking for and/or the problem you're trying to address?
JOHN DEERE 1700 (A53084)
JOHN DEERE 1700...
UNUSED CHERY INDUSTRIAL SINGLE GARAGE METAL SHED (A51248)
UNUSED CHERY...
2022 CATERPILLAR 980 WHEEL LOADER (A51246)
2022 CATERPILLAR...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2023 Maxx-D TDX Tandem Dual Flatbed Tilt Trailer (A53473)
2023 Maxx-D TDX...
2016 Dodge RAM 2500 (A50123)
2016 Dodge RAM...
