BH65 backhoe dolly build
/ BH65 backhoe dolly build #1
tractchores
Ma
Kubota b2920
I built a dolly for my BH65 backhoe over the weekend and thought I would share the info and design with others since I used another members post to build it. Basically I copied this post: http://www.tractorbynet.com/forums/kubota-owning-operating/130291-bh65-dolly.html with a few minor mods. I built a beam using 3 2x4's on end that was 40" long. I then built a small platform for the bucket that was made with 2, 2x4's side by side and 16" long. I connected the beam and platform with 2, 2x4's side by side and 48" long. I screwed it all together so that the entire rig was 48" long with a big beam on one end and a platform on the other end. I then put Caster wheels from home depot in all 4 corners. I elected to use 4" rubber wheels with a ~250 lb load rating. I went with rubber wheels rather than hard plastic so that it would roll on my not always clean garage floor. I bolted the wheels onto the bucket platform and used lag screws to attach them to the beam. The rig is very solid and it actually is at the perfect height for my 2920 and lines the BH up perfectly so I don't even need to use the stabilizers to remove it.
Here are the pics: bh65Dolly1.jpgbh65Dolly2.jpg
/ BH65 backhoe dolly build #2
Great Job!!
Thanks for the pix.
A.Metcalf
Great Job!!
Thanks for the pix.
A.Metcalf
Thanks. Got a PM from another members asking me how I liked my 16" bucket... and didn't even realize I had a 16" bucket! I thought I had a 12, which is what the tractor was listed with when i bought it... just never thought to measure it. With that in mind I think if I built another of these dolly's I'd extend the bucket platform 4" wider than the bucket (I built it for a 12") so that there's plenty of contact area when you put the weight on it to lift the BH onto the tractor.
/ BH65 backhoe dolly build #4
So when you put the BH back on, You drop the out riggers to raise and lower the lower frame into the carrier, then push it forward with the dipper and bucket to get the top pins in.....Will that dolly be able to take the force of the BH pushing on it with out turning into toothpicks?
It turns out that the height of the dolly means that the BH lines up with the tractor just above the slots for the pins, so I don't need to use the stabilizers to lift it at all. I just curl the bucket out and it puts the pins in their slots and raises it up. The bucket platform takes a lot of stress during that maneuver and it lifts the part of the dolly with the bigger Beam when I do this, but it seems to handle the weight without any issues. I probably wouldn't go lifting the rear of the tractor completely off the ground with the bucket on the dolly, but you don't need to do that to attach it. We'll see how it holds up over time, but so far after trying it a few times it doesn't seem any worse for wear.
/ BH65 backhoe dolly build #6
Very nice!
Very nice!
Thanks. Btw it is still holding up after a few months and more than a dozen times putting the bh on and off, so it seems up for the forces involved.
/ BH65 backhoe dolly build #8
Nice job. I know this is an old thread but I'm getting a BH65 for my B2620 and will want a dolly for it. Thanks for posting.
Thanks! Happy to say it is still holding up well.
/ BH65 backhoe dolly build #10
How does my BH-77 compare size wise to your BH-65? I want to make a dolly for mine too
Sent from my iPhone using TractorByNet
/ BH65 backhoe dolly build #11
lol I build the same for mine works great till you hit a joint in the floor. And CanuckPT just build it bigger, make sure you get the heavy duty wheels that can take the weight. Got mine from good old Harbor F.
/ BH65 backhoe dolly build #12
Thanks! I have improvised for now, I picked up some 1000# furniture dollies from TSC last week & I used 3 of them for now.
/ BH65 backhoe dolly build #13
Sorry for resurrecting an old thread.
Built something VERY similar, using the small moving dollies from Harbor Freight, I used three of them and sort of copied this design. Works extremely well on a concrete floor. makes installing the backhoe so easy.
The 'T' part of the design is actually much wider than it needs to be, and for my small backhoe, a B65, probably only two moving dollies would be necessary, one in front and one under the bucket. I may modify mine.
Sorry no pic's
/ BH65 backhoe dolly build #14
Thank you to all who helped design this bh dolly. I pretty much copied what y'all did. It worked fabulously. Once I got the bh on the dolly, I could really tell there was a lot of weight on it. It worked fine, but if I was starting over, I would try to build it out of oak and maybe look for some better wheels. But, it does seem to work just fine as is. Thanks all!
Photos: http://www.fototime.com/inv/0DBCAF118CB4248
Howard
Looks good! The wheels are definitely the most important part, particularly the weight rating. Mine's still holding up after 5 years and somewhat rough treatment. It's amazing how much easier it makes life putting on and taking off the BH.
Caterpillar C Series Backhoe Service and Parts Manuals (A63117)
Caterpillar C...
2022 John Deere 612R Sprayer (A63111)
2022 John Deere...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63689)
2006 Cadillac GM...
2016 Jeep Compass SUV (A61574)
2016 Jeep Compass...
2016 FORD F-550XL SUPER DUTY SERVICE TRUCK (A64280)
2016 FORD F-550XL...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
