BH Lines Too Short?
   / BH Lines Too Short? #1
TORQUIN
Powhatan, Virginia
Kubota L3830
I am trying to understand how the BH install goes on an L3830. Does the BH come with a kit of lines that are a particular length? I am trying to figure out of I should go back to the dealer and complain because my lines for the BH are too short.
Here's the situation. The male line coming form the BH to the tractor is about 3 feet long, from the front of the BH. This sucker is in the way because it is so long. The other line, the male from the tractor to the BH, which gets looped back to the tractor when the BH is disconnected, is about a foot long, from the bracket that holds the female connector on the tractor. When I went to hook up the BH yesterday, after having it unhooked for about 4 days,. I found that it had leaked down enough that I could not back under the hooks on the sub-frame. I went to hook up the lines so I could lift the BH but I was about 5" short of being able to connect the male tractor line to the BH. This was with the subframe touching the pins on the BH.
I ended up having to lift the front of the tractor up and shifting it back with the bucket to get the sub-frame under the pins, and get it close enough to hook up the male tractor line.
I am thinking that the dealer made the line too short when they installed the BH. /forums/images/graemlins/confused.gif
Any opinions or advice on this will be appreciated.
Thanks,
Chris
I was reading the BH manual and I found that it states, when reconnecting the BH, to "back the tractor to within 10-12 inches of the BH, and hook up the hyd lines." There's NO WAY that short line will reach that far. Since the manual also says I should have lowered the BH to the ground after disconnecting it from the tractor, I KNOW my line is too short. That's a LONG way from the tractor remotes.!
It's going back to the dealer tomorrow to get that fixed.
Chris
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
JOHN DEERE 3032E TRACTOR (A54756)
JOHN DEERE 3032E...
2012 Ram 1500 Quad Cab Pickup Truck (A53422)
2012 Ram 1500 Quad...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54607)
2019 FREIGHTLINER...
2025 Unused LandHero LDH-T460XX Mini Skid Steer (A52377)
2025 Unused...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
