BH for plow and tiller?
   / BH for plow and tiller? #1
rooftrussman
Northern Virginia
Ford 1210 (1986)
I've got a 1210 Ford w/BH and loader. It gets used for odds and ends of building jobs. I've always used a hand fork for tilling a small garden every year. I have an 8 and 16 inch bucket for the BH. Any thoughts on the best way to tackle this. Even if I had a tiller attachment, the time to switch out wouldn't seem worth it. The two garden areas together are a total of maybe 400 square feet.
   / BH for plow and tiller? #2
I have seen backhoes used to turn small gardens much as you would with a spade, particularly in new soil. A local guy built two flower gardens for his wife that way that are about the size you are talking about.
   / BH for plow and tiller? #3
I used my BH a few weeks ago for a friend to open up a new garden. I started on one end and made a strip about 8 feet wide and 30 feet long. I just extended the hoe about half way with the teeth straight down. Put it into the soil about 5 inches (just about to where the teeth were burried but the bucket was not sinking in yet) and scratched sideways back and forth. Then pulled the bucket about 6 inches closer and repeated. Had to drive forward several times but in the end the soil was pretty well broken up and she was able to plant.
I'm sure this method didn't do as well as a real tiller would have, however as you said if it's already mounted and ready to go I think it's a decent option and it definitely worked out for us.
Brad
   / BH for plow and tiller? #4
How I do it.
I have a BX23 with a BH And a BX1500 wth a 4' tiller
   / BH for plow and tiller? #5
I don't see why it wouldn't work. Just don't dig too deep and dump your topsoil
in the bottom of the hole. 8-10inches max.
Heh, brings back memories of my use to be neighbor. He was a contractor and had two full sized TLBs. One year his wife was having a hard time harvesting potatoes from the garden as it was a very dry year and the ground was very hard. Backhoe to rescue. Harvested potatoes in no time flat.
   / BH for plow and tiller? #6
I've used mine to break up the hard pack underneath in my garden. As mentioned if you just 'stir' it and not bring up the subsoil it should work 'ok' mine was not very smooth after I was done.
   / BH for plow and tiller? #7
did this with my new garden this spring - worked great. Not as fast as a tiller for sure but if you got the hoe you might as well use it!
   / BH for plow and tiller? #8
Well, if you are going for increased seat time...why not...:rolleyes:
I've got a hammer...that sure looks like a nail to me...:D
   / BH for plow and tiller? #9
I have made three small garden plots in the last year with the backhoe. All were terraces so I was also moving some dirt, but the ground was broken up well and ready for soil amendments.
Steve
TEST BID LOT (A50775)
2012 Volkswagen Jetta Sedan (A53424)
2012 Volkswagen...
1990 Ingersoll Rand 185 Towable Diesel Air Compressor (A52377)
1990 Ingersoll...
2017 INTERNATIONAL PROSTAR (A53843)
2017 INTERNATIONAL...
2010 CHEVROLET SILVERADO (INOPERABLE) (A53843)
2010 CHEVROLET...
2015 CASE 580N (A47477)
2015 CASE 580N...
