BH Control Breakage??
   / BH Control Breakage?? #1
Libertine
East Central Mo
TC40 16LA FEL w-QT & 758c BH
Did a search & couldn't find anything on this. The BH control levers (on a 758c BH) activate small ball joint fittings which then activate the hydraulic control flow rods (which are themselves connected to the hydraulic distibution block beneath the controls). The fitting has a small stud coming out of the ball (which is in a socket at the end of a rod attached to the control lever plate) which runs through the flow control rod (held on with a nut). You can see the way they work simply enough by lifting the rubber cover.
Question. I have broken several of these fittings since getting the tractor (the only failure/breakage since buying the tractor - 125 hrs on it). Is this endemic to the design, or, am I just too hard on the control? The reason I ask is that in ordering replacement parts yesterday I ordered only one extra. If it's in the design maybe I should order a half dozen - they're easy enough to replace if you have them on hand. Anybody else had this problem?
Thanks.
JEH
   / BH Control Breakage?? #2
You might try taking your extra new one, to Granger or some other industrial supply place to try an match it up with a heavier duty version of the same thing. I know when looking at catalogs, that they have several different versions and prices.
   / BH Control Breakage?? #3
I agree with Jerry. We use those and you can buy a heavier one that will last much longer. As for what's happening, I would think that you're a little heavy handed, but it should be designed to withstand a little extra strain than required to operate the controls.
   / BH Control Breakage?? #4
We sell many of these backhoes every year. I have never had the linkage break that you are talking about I dont even stock the part.
   / BH Control Breakage?? #5
I have had a part break in the control mechanism of my 759C.
The problem I had was with #13.
It is just a 1/4" bolt by 2" long (I think). I used a grade 8 bolt and it seems to last longer. In the begining I was breaking them often. Mostly on the right control (dipper and curl). Once I got a little better with the controls the less often I replaced them. As someone mentioned heavy hands on the controls /forums/images/graemlins/smirk.gif /forums/images/graemlins/smirk.gif. I haven't replaced any in 2 years now.
DavidJ:
<font color="blue">I would think that you're a little heavy handed </font>
Ah, yes. Don't doubt it. In fact my favorite tool in the tractor toolbox (as it was in my old farmall I sold when getting the NH) is a 2 lb. blacksmith mallet. Spencer200 is (I guess) a dealer and says he hasn't had to replace them, so, you're no doubt correct. The suggestion (& JerryG's) to look for heavier duty is good. Will do that when get parts in Tues.
Roski:
Thanks for drawing (have that, but no scanner here). The part I was referring to is #11 in drawing. Havn't had part #13 break (yet). Maybe will pick up spare (or higher # bolt) for that too. The control is easy enough to fix IF you have a part handy. Maybe I should just keep the spares in toolbox so always have one handy! You mentioned the 759 BH - wish I'd been able to get that on the TC40. The 758c is ok but just a bit short on reach and strength. On the other hand, it's a whole lot easier than me with a pick, shovel and wheelbarrow!
Anyway, thanks for the feed-back. Guess the answer to my question is the part may be a little weak, but it's more my ham-handedness that is the problem. Thanks again.
JEH
OTTAWA SPOTTER TRUCK (A52708)
OTTAWA SPOTTER...
INGERSOLL RAND SD25F PADFOOT ROLLER (A52709)
INGERSOLL RAND...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A56435)
2014 Doyle Dry...
2008 WABASH 53FT REEFER TRAILER (A58017)
2008 WABASH 53FT...
2020 DRAGON ESP...
2016 Chevrolet Tahoe SUV (A56859)
2016 Chevrolet...
