BH casting broke? Any dealers here?
   / BH casting broke? Any dealers here? #11
I just measured the sway lock pin on the M59. It gets a lot of wear since we often use the BH bucket and thumb to carry rather large rocks from the surrounding mountains down for landscaping.
Pin size after 20 years is 1.0045". Holes in castings are slightly egged, 1.045" to 1.058"
So basically we are looking at a one inch pin with an impressively hard plating. It shows no wear.
Originally made to go into two holes (double shear) with twenty thousands clearance all round. Holes now worn about an additional 0.005" only in the stressed area.
That's a tight fit. The clearance needs to be tight to prevent any side swing.
If your new warranty part measures substantially differently, consider flanged bushings. Use iron- impregnated bronze to handle your low speed shock loading. McMaster has those bushings for a few bucks.
BTW, your photo of the casting looks good to me. Hard to know for sure without more examination, but my first impression is that the casting quality is excellent. That's backed up by the fracture angle - that angle shown is typical for a good quality material that is simply stressed beyond its yield strength. Basically that's a textbook fracture.
rScotty
They texted me and they ordered the casting, they will pick it up when it comes in, fix and return it
   / BH casting broke? Any dealers here? #13
That’s your best solution. Good on Kubota.
I’d still double check by measuring the new clearance.
rScotty
Looks like I will drop her off Monday, so they have Tuesday and Wednesday planned for my girl.
I would of had to wait a week for pickup, shops only 30 min. From work, so I'll take a late lunch.
They just called and will drop it off tomorrow, I miss her 😔 😢
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
2003 INGERSOLL RAND SD-105DX SMOOTH DBL DRUM ROLLER (A52707)
2003 INGERSOLL...
S/N: 5D121002416 (A55787)
S/N: 5D121002416...
2008 Ford F-150 Ext. Cab Pickup Truck (A55852)
2008 Ford F-150...
JLG 1255 Telehandler (A55315)
JLG 1255...
