Beware John Deere 4*20 series owners--antifreeze leak
   / Beware John Deere 4*20 series owners--antifreeze leak #21
When the service tech called me with a quote, I asked him how or why this would happen. Just trying to pick his brain, he mentioned that it could be a number of things and that JD has a specified torque pattern for the timing cover and the oil pan. My thinking was that if I spend my time to do it, and it still leaks, I'm gonna be p i s s e d off twice. Somethings are worth the money......
   / Beware John Deere 4*20 series owners--antifreeze leak #23
I had my head gasket replaced on my 4200. It ran around $2300. I don't remember what it had for hours at the time of repairs. It was hard to take but had to have it done.
   / Beware John Deere 4*20 series owners--antifreeze leak #24
That sounds like a pile of money for the task provided. I think I would have wrenched that one myself. The computers these days practically take you by the hand and explain what to do next. How did we ever live without them ?
   / Beware John Deere 4*20 series owners--antifreeze leak #25
I clock about 600 hours a year on my '05 4720 and never had a coolant leak. That and fuel are about the only fluids that never leaked though, oil is another matter...
   / Beware John Deere 4*20 series owners--antifreeze leak #26
I have a 2007 4320 that had to have the engine replaced at 500 hrs now the new engine is leaking antifreeze. Only 1000 hrs on the whole tractor
   / Beware John Deere 4*20 series owners--antifreeze leak #27
Where is it leaking? Are you sure the hose clamp(s) doesn't need tightening.
   / Beware John Deere 4*20 series owners--antifreeze leak #28
What happened that caused the engine replacement?
   / Beware John Deere 4*20 series owners--antifreeze leak #29
Additional Info: Both of my 2007 and 2010 4320 open station tractors leaked anti freeze at the hose connections. Both were easily fixed with tightening the clamps. Sometimes it is difficult to actually trace the leak but it's really easy to just tighten all hose clamps and at least eliminate that as source of leak, or fix the problem. I'd do that first if you haven't already done it. I also had a leak at front of the 2007 4320 (different time) near head gasket but don't remember details and that was covered under warranty. May be similar to yours.
   / Beware John Deere 4*20 series owners--antifreeze leak #30
Tractors aren't the only equipmet with this problem. I had a Chevy S-10 p/u. Was a 1980's something. Engine failed. Diagnosis was the antifreeze was 3 yrs old, had acidified, and ate thru a gasket. The engine design had only a gasket separating coolant channels from oil channels, as I recall. The a/f leaked into the oil, and eventually ate the bearings. When they dropped the oil pan, the bottom was filled with glitter -- metal particles that had been chewed up by the a/f. Chev said sorry, out of warranty. Repair shop said they had fixed couple dozen with the same problem. Always charming to find these things out after it happens to you. Today's internet helps, but no always.
New Land Honor 5400 LB Ratchet Binder And Chains (A53002)
New Land Honor...
WESSEX CRX 180 LOT NUMBER 171 (A53084)
WESSEX CRX 180 LOT...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2018 Chevrolet Camaro 1LT Coupe (A51694)
2018 Chevrolet...
Tiger Mowers 90in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 90in...
2002 International 9200i Truck (A53472)
2002 International...
